DIY 3DOF simulator use SMC3 Arduino
Discussion in 'DIY Motion Simulator Projects' started by leductrinh, Aug 19, 2020.
  1. leductrinh
    leductrinh New Member
    32Coins
    Hi guys, I'm from Vietnam . This is my biggest DIY project ever
    I have purchased the following parts:
    1. 03 Motor My1025 24v 300W 2750 rpm
    2. 06 Steel ball joint M10
    3. 03 Wormgear Tsubaki TM10E ratio 1:10
    4. 03 electricity supply Meanwell 24V 25A
    5. 01 Universal joint
    6. I had 03 BTS7960 and Arduino uno r3 of the previous project
    updating....
    • Like Like x 5
  2. leductrinh
    32Coins
    7. 03 jaw coupler (for mount shaft motor with wormgear)
    8. 03 potentiometer
    9. 03 helical coupler (for mount out shaft wormgear witch potentiometer)
    Yesterday, I tried connecting the engine and gearbox, and happily, the lift was strong and fast.
    Today I will continue to draw the structure of the rig
  3. leductrinh
    32Coins
    A lot of editing is needed before doing this.
    I try to start doing the mechanical part this weekend
  4. leductrinh
    32Coins
    electric box for rig
      113.1 KB
      393
      195.8 KB
      418
      134 KB
      410
      177.1 KB
      416
  5. leductrinh
    32Coins
    Try to finish before noel
  6. amer
    amer New Member
    Malaysia
    157Coins
    nice project.. how do you connect upper platform with the base to get the movement for traction loss? what software you are using for 3d design?
  7. ahoenksiluman
    ahoenksiluman Member
    indonesia
    89Coins
    is that 1:10 enough..??
    i use 1:50 for the same motor, but it still progress....not running yet...
  8. leductrinh
    32Coins
    I connect as attachment picture , I use sketchup software for the design
    I'm hoping 1:10 will be enough. Try to get the correct balance to reduce the pressure on the gearbox
  9. cubizme
    cubizme New Member
    17Coins
    DC motor, Arduino
    Nice project, hope to see your rig soon.
    When we're done, we will exchange, kkkk
  10. leductrinh
    32Coins
    update....
  11. amer
    amer New Member
    Malaysia
    157Coins
    hi, nice work.. can you show how do you attach lever to motor shaft? Im struggling to find the best way on how to attach the lever to the shaft..
  12. leductrinh
    32Coins
    i'm used parallel key
  13. leductrinh
    32Coins
    Hi all,
    it works pretty well, but I have a question:
    How to install simtool plugin for games running on steam app
    151,991Coins
    +11,061 / 56 / -2
    Great to see your rig in action :thumbs
    Plugins for all games are installed via the SimTools PluginUpdater, make sure SimTools is closed, open the PluginUpdator, and drag the plugin zip file on to the PluginUpdator, which will then install it.
    It is a good idea to grab a copy of the SimTools manual, which explains plugin installation and everything else about SimTools and its configuration: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    You can also find hand tips in the FAQs, like how to refine a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    Speaking of which, sway should lean away from a corner, yours seems to be opposite in the video, this is what SimTools expects in terms of axis configuration: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
  15. leductrinh
    32Coins
    Thanks for reply
    I followed the instructions you suggested and ran it successfully with dirt4 game (steam version)
  16. man05ru
    man05ru New Member
    53Coins
    2DOF, 6DOF
    @leductrinh can you post your simtools settings?
