VR Motion Cancellation - Time to test!
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by noorbeast, May 6, 2017.
  1. Zeroselect
    Zeroselect Member Gold Contributor
    Maryland, USA
    111Coins
    4DOF
    The Quest 2 is starting to looking appealing as well.
    152,977Coins
    +11,116 / 56 / -2
  3. SeatTime
    Just been carrying out some tests with Pimax 8KX and their PiTools motion cancellation capability and it so far seems to work very well. Really simple to setup - just turned on my index controllers and selected one of them as the sensor in the PiTools 'Motion Cancellation' and then open a game. You although need to orient them correctly.
  4. CraCk
    CraCk Member Gold Contributor
    Made in Ukraine
    670Coins
    Hi
    I have a questions. Oculus quest/quest 2 support vr motion cancellation? Connecting to pc cable
    152,977Coins
    +11,116 / 56 / -2
    I have a Quest but have never actually tried it, but would expect it would be treated the same as the Rift S would.
  6. KydDynoMyte
    KydDynoMyte Fool's Gold Contributor
    RTP, NC
    40Coins
    Using Virtual Desktop version 1.17.1 to stream over wifi to a Quest 1 or 2 and OVRMC seems to work well using one of the controllers as the tracked object. A few of us in the YawVR discord have rolled back to 1.17.1 to keep using it. Then plug the hotas into the quest using a hub with VirtualHere and you're completely wireless to use that 360° yaw.
  7. TheCalVRsimer
    TheCalVRsimer New Member
    346Coins
    3DOF, Motion platform
    Any update for motion cancellation and WMR such as the Reverb G2 by any chance.
    Thanks for your reply.
  8. SilentChill
    20,598Coins
    Works perfect with Mover and the Virual Tracker :)
  9. TheCalVRsimer
    346Coins
    Thanks for your response.
    Completely unfamiliar with MOVER. I have a D-BOX motion system, would MOVER work with D-BOX, and if so is there any docs somewhere on how to set it up?
    Thanks for your help.
  10. SilentChill
    20,598Coins
    Sorry you're out of luck DBOX systems are totally closed up no way to use it im afraid
  11. TheCalVRsimer
    346Coins
    Oh wow, gonna get in touch with them and see if they have any plan in their future to allow motion comp.
    Thanks again for your quick response
  12. Flymen
    Montreal, Canada
    2,476Coins
    DC motor, 6DOF
    After 18 week finaly !!!
    We will see it tomorow !!
    Maybe i will need your help !!
    @SilentChill
  13. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,034Coins
    3DOF, DC motor, Arduino, 6DOF
    Beside the work bench. Perfect place to keep the lens clean. ;)
  14. hannibal
    hannibal Active Member
    4,492Coins
    @Flymen congrats on your HP reverb G2. i was a late order, so ill prob get it in Feb
  15. born2bslow
    born2bslow Member Gold Contributor
    272Coins
    I have a DoifReality P3, but I also run 4 transponders using SC4 software in chassis mode. The problem I have is that the vibrations from the transponders are interfering with the motion cancellation. Is anybody aware of any solutions?
    I've been thinking about making an extended bracket, attached to the base of my rig below the transponder vibration to bring the tracker up alongside my head, but the transponders shale the whole upper section of the rig. It's only a problem for traction loss movements.
  16. TheCalVRsimer
    346Coins
    Would it be possible to set motion cancellation with the HP Reverb G2 using a vive tracker and two Vive base stations for:
    1. iRacing and Steam VR
    2.MSFS2020 and OpenXR
    And if yes, is there a tuto somewhere?
    152,977Coins
    +11,116 / 56 / -2
  18. TheCalVRsimer
    346Coins
  19. KydDynoMyte
    RTP, NC
    40Coins
    Couple recent things that might help some.
    Streaming to the Quest 1 or 2 with Virtual Desktop and using OVRMC (or maybe any other mc software) you should be able to use the latest version of Virtua Desktop instead of the older v1.17.1 version by adding the /DisableRenderPose flag when you start Virtual Desktop Streamer.
    Saw this today that looks very promising for more easily mixing tracking technologies and possibly having motion cancellation added to it so everything is in one nice little package for us.
    https://www.reddit.com/r/WindowsMR/..._video_showing_boundary_grid_using_wmr_index/
    Edit: Seems I jumped the gun there. Seems he is currently using SpaceCalibrator to mix the tracking technologies. He still seems interested in adding motion compensation to his app though.
  20. Dschadu
    Dschadu Active Member
    1,936Coins
    Sorry, OVRMC does not support multiple tracking spaces yet. You have to use a WMR tracker or the virtual tracker for mover.
    And also, you have to use OpenVR / SteamVR. It will not work for other launchers.
