Question I'm Sure this is the wrong place.... but I need help
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Slybynight, Nov 10, 2020.
  1. Slybynight
    Slybynight New Member
    128Coins
    Hi Guys
    I couldn't find an appropriate sub-forum, but I have a specific question.
    I have a 5 monitor setup running on 5 PS3's running GT6.
    I love it.
    I have no interest in VR.
    My rig is ready to install 2DOF motion (cardan and anti rotation in place, arduino and wiper motors sitting on bench....), but I really want software that will:
    1. output motion data
    2. enable me to play online
    3. support 5 monitors - yes ALL 5. 3 will not suffice!
    Happy to buy PC, but confused over which software will do all 3 of the above.
    Please help.
  2. yobuddy
    51,667Coins
    @Slybynight
    You actually need different stuff for each of the 3 things you listed buddy.
    You need motion software for this like SimTools.
    This is game dependent, if the game supports it, it will work.
    (and you online lol)
    This would be dependent on your PC setup.
    Nvidia has a triple monitor solution that can be extended i bet
    (but have not looked into it)
    Hope that helps,
  3. Slybynight
    128Coins
    I didn't word it very well. The crux of my question is "Will all PC race sims support 5 screens IF I have sufficient graphics cards?"
    I see lots of triple screen stuff, but not many 5 screen.
  4. yobuddy
    51,667Coins
    Look up nvidia surround.
    It basically lets you setup a multi-monitor system where the PC thinks the end result is a single monitor.
    Should work as well as a tipple motor setup since its using the same stuff but with 2 more monitors.
    (i don't have the hardware to test it out thou)
    But I believe its what you are looking for.
    Take care,
  5. Slybynight
    128Coins
    Thank you so much @yobuddy - very informative. So basically, stick with Nvidia and I should be good for all main race sims?
  6. yobuddy
    51,667Coins
    Well AMD has it also, but it's called 'Eyefinity' I believe.
    https://www.amd.com/en/support/kb/faq/dh-014
    With all the new hardware coming out, I personalty would wait till after the holidays to build a new PC.
    It's been a fun few months watching AMD knock the socks off Intel, and giving Nvidia a run for their money.
    As far as gfx goes, if you want ray-tracing, Nvidia is really the only game in town still.
    If your not worried about ray-tracing but want 4k, I would still go Nvidia.
    If your pushing 1080p or 1440p monitors thou, AMD may be a better choice.
    We will know more once the hardware has been out for a bit longer.
    Please know that not allot of people have 5 monitor setups, myself included.
    So it's hard to say for sure how the setup will go.
    I would probably call/email EVGA (if going Nvidia) and tell them what you want to do.
    I'm sure they will point you the right direction.
    Take care,
  7. Dan Aitcheson
    Dan Aitcheson Member
    New Zealand
    - 3Coins
    You will need 2 graphics cards to run more than 4 monitors. I don’t know if it is still the case, but nVidia surround used to be limited to 3 monitors, AMD eyefinity supported 6 (they even made some special cards with 6 Dp outputs)
    I used to run a 4 monitor surround and I had 2 AMD cards to do it as nVidia didn’t support more than 3. That may have changed now, you’d need to research it.
    AMD would also allow mixed resolutions
