Question need help diy simracing project
Discussion in 'DIY Motion Simulator Projects' started by cheneau, Nov 25, 2020.
  1. cheneau
    cheneau New Member Gold Contributor
    - 65Coins
    2DOF, 3DOF
    Hello friends, I present my project to you I have a good foundation in DIY but I am bad at computer programming. I would like to run 36v skateboard motors with simtools, anyone to help me? power supply ?, and motor control? thank you in advance
    152,265Coins
    +11,066 / 56 / -2
  3. cheneau
    - 65Coins
    2DOF, 3DOF
    Thank you very much for the time spent! on a website in France, they tell me that I do not order 36v motors with sabertooth! . what is your opinion ? finally, can we use the hall position sensor for the position of the installation? Thank you in advance for your reply !
    152,265Coins
    +11,066 / 56 / -2
    You will need to check the specs yourself and decide, the normal use, and safe way to go, is 24v and max is 36v.
