Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. morpwr
    morpwr New Member Gold Contributor
    36Coins
    Hopefully we get some more news on whats coming soon.:)
    And when...
  2. morpwr
    36Coins
    So when do we get some news on the awesome?
    153,764Coins
    +11,149 / 57 / -2
  4. morpwr
    36Coins
    I know and im not saying you just whip out a new version in a week. But some news on it would be great. I ran across the new version by accident so its been kept pretty quiet until recently.
    153,764Coins
    +11,149 / 57 / -2
    The normal process is development, limited closed feedback and testing, wider testing, then release. It is up to @yobuddy to determine what to share and when.
    Life can also be distracting, and I know this childhood dream has recently grabbed @yobuddy's attention :rolleyes:
  6. yobuddy
    51,529Coins
    37h and 48mins until I pick up the frame... :grin
    153,764Coins
    +11,149 / 57 / -2
  8. Mu-KwangKim
    South, Korea
    - 689Coins
  9. morpwr
    36Coins
    I just found a rare Oldsmobile aurora go kart kit and im soooo tempted.....so i completely understand that its not his only distraction. Google it because its cool.
  10. morpwr
    36Coins
    I wasnt trying to be a nag and had no idea where yobuddy was in the develpment process. Just looking for some clues as to how far along it was.;)
  11. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    2DOF, DC motor, SimforceGT
    Hello people on the forum, you know that I have the same problem that we had with the update of simtools 2.5.0, I am currently using 2.5.1 and the same thing happened as the previous one. look at the photos
    control pc
    Someone did the same ??
  12. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    Hello guys, good morning, sorry for the inconvenience, I know that some pairs must be resting a bit, but I want to ask you if this problem happened to someone else, it happens with the last updates of win 10.
  13. yobuddy
    51,529Coins
    No worries at all buddy.
    I should be able to do a bit of show-and-tell soon.
  14. Stefan4DOF
    Stefan4DOF New Member Gold Contributor
    Engineer
    Denmark
    180Coins
    DC motor, Arduino, 4DOF
    hi yobuddy
    I am about to start my 4DOF project. do you have any idear if it would be a waste of time to start using Simtools V2.5.1 instead of just waiting a bit longer and then start up with Simtools V3?
  15. Michael Jeffries
    Michael Jeffries Member Gold Contributor
    485Coins
    Motion platform, 4DOF
    id love to know when v3 is scheduled to drop
  16. noorbeast
    153,764Coins
    +11,149 / 57 / -2
    The standard answer is generally 'when it is ready' ;)
  17. yobuddy
    51,529Coins
    @Stefan4DOF,
    Your license will work for both software packages at the end of the day.
    And you can even run them side by side (but not at the same time of coarse).
    V3 is a complete, more modern, rewrite of SimTools.
    Streamlined, to be easier to understand, with a more of a 'pictorial' menu system.
    But in the end of the day. they both will get your sim up and running.
    And the concepts to setting them up are roughly the same.
    You could always play with the demo of v2 until v3 drops.
    But v3 will come in stages.
    As I can't really add a bunch of "bell's and whistles" to v3 until I have a solid tested base to work on.
    So the first version of v3 will be Alpha1, and it will support motion only (and new plugins are required).
    (dash, vibe and a few other things will be added in a later alpha version)
    So v3 will roll out in stages, with more and more being supported, until its fully up and running.
    Hope that helps buddy!
    Take care,
  18. Mechromancer
    434Coins
    Man...can't wait! :D
  19. the2jakes
    the2jakes Member Gold Contributor
    137Coins
    Hi @yobuddy,
    I keep having an issue with my Motion Rig these last weeks (stops suddenly working while in game, and only restarts when I unplug/replug the usb cable that goes to the arduino). Are there logs generated by Simtool 2.5.1 I could look at ? (couldn't find any).
    Thanx ;)
  20. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    Probably your problem is usb cable. Try to change with another one MAX 1,5mts !! I try with 3 mts, 2mts, and same problem occuor.
