Question Arduino Reset
Discussion in 'SimTools DIY Version' started by terry wells, Nov 24, 2020.
  1. terry wells
    terry wells Active Member
    retired military
    minnesota USA
    717Coins
    3DOF, Arduino
    Why do I need to keep resetting my Arduino board for motion when I bank right? Motor #1 keeps shutting down. Both motors are setup the same in SCM3.
    hpwells1.
  2. yobuddy
    51,524Coins
    This usually happens when a motor can't get enough power to move the sim.
    (Or the balance is a bit off.)
    Please try running the sim for a bit without anyone in it, does it shut down?
    Chat soon buddy,
    153,740Coins
    Can you please post pictures of all of your settings, and a video of the rig and game screen would also assist trouble shooting.
  4. Gadget999
    12,132Coins
    the potentiometers are going out of range and shutting the motor down ?
    push the motor back into range and see if the motor comes back to life
  5. terry wells
    retired military
    minnesota USA
    717Coins
    3DOF, Arduino
    Yes it shuts down without me in it. I set the plane in AP and execute a right turn/bank and the motor hangs up when it is at it's highest pos. The pot's are hall continuous turning. Thanks for the replys
    HPwells
  6. yobuddy
    51,524Coins
    I found this in the thread for the smc3 sketch...
    Seems like the culprit to me?
    Let me know how it goes buddy.
    Take care,
    Dustin
  7. terry wells
    retired military
    minnesota USA
    717Coins
    3DOF, Arduino
    OK, I will give that a try. Does the MAX LIMITS and the CLIP INPUT need to be somewhat the same??
  8. yobuddy
    51,524Coins
    Hi @terry wells,
    The way i read it, anything after clip limits the interface does its best to back-petal out of this region.
    Anything after max limits it will shut down.
    So if you set them the same value you never give the interface a chase to "get out of the red zone".
    Instead, it just shuts down.
    So for a test, try lowering your Max limits to 20.
    Chat soon,
  9. terry wells
    retired military
    minnesota USA
    717Coins
    3DOF, Arduino
    @yobuddy
    Should I do this on both motors?? Motor #2 is not giving me any problems.
  10. yobuddy
    51,524Coins
    I would, as the shutdown threshold is still there if something goes wrong.
    Otherwise you don't leave any room for the system to backpedal if it needs to.
    Take care,
  11. RacingMat
    21,081Coins
    I agree with yobuddy
    https://github.com/SimulatorMotorController/SMC3Utils
    Clip Input Used to create a band at either limit of the target range beyond which any values sent to the SMC3 are clipped. In addition to this clipping, if the motor feedback does move beyond this range (typically through inertia), the SMC3 will attempt to brake the motors hard by driving them in reverse until they are back out of this limit zone. The value can be anything from 0-255 (however can’t be less than the current limit setting). Reverse braking is applied in the band between the Clip Input and the Max Limit settings. Reverse braking can be disabled - refer to PWMrev.
    @terry wells: topic title is misleading as it is not an arduino resseting itself
    maybe you could rename the topic "Motor keeps shutting down in SCM3"
  12. terry wells
    retired military
    minnesota USA
    717Coins
    3DOF, Arduino
    I set both for max load to 20 and I still have the same problem. It only happens when the actuator to motor #1 is in it's upper position. All other functions work fine. I replaced the hall pot , and that was not the problem. The only thing I have not done yet is to replace the motor controller or the motor. I have installed a reset switch on my platform so that I can reset the Arduino board from the platform. I would rather fix the problem rather than use the switch. And yes this is a scm3 issue but it is the Arduino board reset that I found to somewhat fix the issue. Thank You and HAPPY THANKSGIVING TO ALL
    Terry Wells.
  13. noorbeast
    153,740Coins
  14. terry wells
    retired military
    minnesota USA
    717Coins
    3DOF, Arduino
    With my Max Limits set to 20 and my Clip Limits set to 155, I still have the problem . Thanks for the reply.
    Terry wells
    153,740Coins
    Have you tweaked your PWMrev, that affects how hard the brakes are applied once the Clip limit is reached?
    Best to re-post current SMC3 settings each time you change them.
  16. terry wells
    retired military
    minnesota USA
    717Coins
    3DOF, Arduino
    My PWMrev is at 150 the same as my PWMmax now and still not working. Could the problem be my motor controller board?? I will posy pictures later because my problem is 2 story's below me.
    Thank for the help
    Terry Wells
    153,740Coins
    I would have expected your PWMax to be higher, and Fpwm to be 25kHz.
  18. yobuddy
    51,524Coins
    I'd swap the motor controllers on the motors and see where the problem ends up.
    Does it stay with motor 1 or swap to motor 2?
  19. terry wells
    retired military
    minnesota USA
    717Coins
    3DOF, Arduino
    I have not switched motor controllers yet, that will be my next task.
  20. terry wells
    retired military
    minnesota USA
    717Coins
    3DOF, Arduino
    @yobuddy
    Could this possibly be the problem (miss match of ver)
