[in progress] Reincarnation. Static SimRig in 2DOF
Discussion in 'DIY Motion Simulator Projects' started by redford 77, Oct 3, 2020.
  1. noorbeast
    153,710Coins
    Either use modified server PSUs, or LED PSUs, I prefer one PSU per motor, as our rigs generate big spikes, for future proofing look at 600w or more, as you may want to upgrade the motors at some point. Alternatively try a car battery, with a PSU keeping it charged up.
    Settings are configured in SMC3, see the next response re possible issue.
    First, make sure your computer is set to English Local: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
    Next, grab a copy of the SimTools manual and keep it handy for reference: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    And make sure you check out the motion profile tuning tips: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    Please post pictures of all of your settings so members can provide tuning advice.
  2. redford 77
    redford 77 Member
    Technologyst of fiberglass
    Ukraine Kharkov
    - 141Coins
    Thanks for the answers and help, I feel I have a long time of trial and error settings))
    I'll start by studying the Simtools manual
  3. redford 77
    redford 77 Member
    Ukraine Kharkov
    - 141Coins
    Unfortunately, with my 100 kg, I cannot carry out tests, settings (the power supply goes into protection, there is not enough current)
    Here is a video of the first tests with my sons driving
  4. redford 77
    redford 77 Member
    Ukraine Kharkov
    - 141Coins
    I just ordered a Dell 700w power supply from the server, I hope that this time it will be enough
  5. redford 77
    redford 77 Member
    Ukraine Kharkov
    - 141Coins
    For a long time I could not figure out why, when starting smc3, the chair stands exactly, and when I start simtools, it becomes on its side.
    I started to check everything, at first I thought that the potentiometer was not working correctly - no, everything is ok,
    then I tried to configure the software - no,
    The problem turned out to be funny and stupid - one thrust going from the motor to the shoulders was 1 cm longer.I did not adjust them evenly during assembly,
    Therefore, I want to say, be careful !!!, do not rush !!!! and check everything 10 times !!!, basically all the big problems are hidden in small mistakes !!!!!
  6. redford 77
    redford 77 Member
    Ukraine Kharkov
    - 141Coins
    By the way, I decided not to risk it and ordered another power supply, so that this time it was definitely enough for the future))
    Took a server unit HP 1200 with 12 volts 100a
  7. redford 77
    redford 77 Member
    Ukraine Kharkov
    - 141Coins
    I finally got the power supply. It is much smaller and more compact than I imagined, now I understand that I made a mistake when using power supplies from a PC.
    I had to tinker a bit with it while I started it, first I soldered a 1kOhm resistor to 33 and 36 terminals, it did not start, then I just put it with a jumper and it worked .. I used 1.5 mm2 wires, 2 for (-) and 2 for (+), total 8 wires for 2 motors, it was specially soldered in different places to distribute the load evenly, until I connected it to the simulator, I will immediately write a post about its work
  8. Dschadu
    Dschadu Active Member
    1,937Coins
    A short tip: remove the flux resedue with isopropanol alkohol as good as you can. Flux resedue can cause corrosion over time
  9. redford 77
    redford 77 Member
    Ukraine Kharkov
    - 141Coins
    By the way, I forgot to do it
    Thanks for the important note.
  10. redford 77
    redford 77 Member
    Ukraine Kharkov
    - 141Coins
    I can finally start setting up simtools,
    The power supply works perfectly, it is very quiet and powerful at a price of $ 10, this is the best option, when setting pwMmax 230 and pwmrev 200, the voltage is kept at exactly 12.5 even at 0.1 does not fall.
    I feel now waiting for me a long time of settings ...
  11. redford 77
    redford 77 Member
    Ukraine Kharkov
    - 141Coins
    Hello everyone, I finally finished everything and everything works as I wanted. I want to say a few words about plugins and settings, I tried to configure the LFS all day, but I could not properly configure the LFS as it strangely transmits signals, the same thing is observed in the Project cars 3 game. But in the games AC, DIRT rally 1 & 2, on the contrary, all the sensations from driving are simply perfectly conveyed, I sit in a chair and smile when I play these games, I just don't want to stop super, I am very pleased with the result ..
    There is one question: can anyone know how to fix this? Simtools conflicts with SimHub and SImHub stops transmitting signal to my dashboard and bass shakers, apparently both programs use the same telemetry transmission channel, how can I fix this and make them work together?
    153,710Coins
    2 applications can't use the same port, but you can port forward, see the FAQs here: https://www.xsimulator.net/community/faq/simhub-port-forwarding.356/
