DIY Actuator from an Existing one with AASD-15
Discussion in 'DIY Motion Simulator Projects' started by iamcanadian2, Dec 4, 2020.
Tags:
  1. iamcanadian2
    iamcanadian2 Member
    floating docks
    surrey bc canada
    90Coins
    Motion platform, 6DOF
    Attached Video of how I converted a 12 volt 8" linear actuator to work with Thanos AASD-15 Motion controller .
    This works so well I had to do a video . I will do another with more details of my Simulator and parts used.
  2. Thanos
    Electronics Engineer
    2,862Coins
    Very good! Perhaps you can add some extra lubricant for the noise...
  3. Gadget999
    12,035Coins
    Who makes the actuator ?
    What ia the speed in mm/s ?
  4. iamcanadian2
    iamcanadian2 Member
    floating docks
    surrey bc canada
    90Coins
    speed is 55 mm per sec. 2 : 1 gear ratio 5 mm per rotation of screw.
    not the fastest but for flight it is very good. I only use 180 mm of the travel in AASD-15 and in the Bff software I have 80% set of travel. Just Setting up for NLC with Simtools!!
    The make of Actuators from servo city are made in Taiwan , Servo city is $400USD . but the ones i have in the link from Ali express are the same dimensions just without the pots. which you dont need.
  5. iamcanadian2
    iamcanadian2 Member
    floating docks
    surrey bc canada
    90Coins
    A silicon Grease? I dont want to ruin the belt? they are pretty quiet I am happy with them so far!
