Racing seats
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Chris Chopping, Dec 7, 2020.
Tags:
  1. Chris Chopping
    Chris Chopping Member
    Mechanical Engineer
    Melbourne, Australia
    - 26Coins
    Hey team,
    post your racing seats below! I am thinking of adapting my current rig with a new seat that’s actually a racing one as it is quite unstable and not thaat comfortable.
    Although budget is tight so any recommendations would be great!
    What do you use? Why do you use it? Mass of it?
  2. knaufinator
    knaufinator Active Member
    Simulation Engineer
    akron,ohio
    1,910Coins
    AC motor, 6DOF
    3A racing seat - I got it for $50 off of Facebook marketplace...~25lbs. Its was originally adjustable back, though I welded it together for more strength as I did not trust the back.. not collapsing. This fit the requirement of cheap and have the harness/belt through holes above the shoulder. I may invest later on a nicer one,.. as this one went through the fabrication process along with the motion platform... and now has.. many burn holes....
  3. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    I just replaced the HORRID Obutto seat after 4 years.... What a POS.... I went to a junk yard and found a nice 2006 Dodge Neon Rally addition car... seat looks great, and is super comfortable!
  4. ChubbyWeasel
    ChubbyWeasel New Member
    USA
    65Coins
    I sold my race seat with the race car so I think for my sim I'm going to try the Jaz Turbo Pro. It's about $110 USD. I thought I read that it only weighs about 10 pounds or 4.5 kilos but I don't remember where I read that.
  5. Sam Neall
    Sam Neall Member
    84Coins
    That is a really good deal. I might have to start looking around for used seats like that because I am in for a upgrade soon. Thanks for the recommendation.
  6. FourOff
    FourOff New Member
    37Coins
    If you want a proper racing bucket seat, used is a really good way to go. Racing seats eventually "expire" (vibration, sunlight, and chemicals eventually weaken the shell, and newer seats have newer safety regulations), making them ineligible for competition use. At that point, they're basically garbage to a race team but will work just fine for sim racing for many many years.
    I'm using my old Sparco Circuit Pro that expired in 2007. Hasn't cracked on me yet, but I just added motion so we'll see :p
    Because these seats have a limited life, I have seen some just completely torn up. You can buy replacement cushions and covers for a lot of expired seats, or take it to an upholsterer.
