SMC3 UTILS V1.01 ENGINES AND IN SIMTOOLS NO
Discussion in 'Ready, set, go - Start your engines' started by robert guasch, Dec 10, 2020.
  1. robert guasch
    robert guasch New Member
    - 3Coins
    HELLO, VERY GOOD, IT WORKS FOR ME IN SMC3 UTILS V1.01 THE ENGINES, BUT WHEN I OPEN SIMTOOLS IT DOES NOT WORK when trying to do the test, knows someone who can pass !!
    Cheers
    153,986Coins
    +11,162 / 57 / -2
    Please post pictures of all of your setting, as there is likely a configuration error.
  3. robert guasch
    - 3Coins
    Here you go
    153,986Coins
    +11,162 / 57 / -2
    Your interface settings are incorrect, as they have an additional space, they should be like this, without any additional spaces:
    [A<Axis1a>][B<Axis2a>]
    You also can't run SimTools and the SMCD3 utility at the same time, as that will create a port conflict:
  5. marcosrobert
    marcosrobert New Member
    Design Grafico
    Sao Paulo - Brasil
    253Coins
    I have the same problem. In SMC3 UTILS V1.01 the motor works, in SIMTOOLS the motor does not work.
    I do not understand
    153,986Coins
    +11,162 / 57 / -2
    Your Interface Settings should be like this, with no spaces: [A<Axis1a>][B<Axis2a>]
  7. marcosrobert
    Design Grafico
    Sao Paulo - Brasil
    253Coins
    Engines switched off with potentiometers. The green line must accompany the blue line. By varying the potentiometer, the line continues (straight)
    Send image for evaluation
  8. yondwangmms
    yondwangmms Member
    - 148Coins
    Try new settings:PWMmax=100 PWMrev=200 Max Limits=0 Clip Input=50
  9. Dimm-vir
    Dimm-vir New Member
    programmer 1C
    Belarus Kletsk
    - 1Coins
    I had the same problem, it turned out that Pot1 was badly connected to the A1 pin of the arduino. I checked all the connections, fixed the break and green line pot1 began to show the position of the motor. The motor will move until the pot shows the limit
