Wagnard
Star Wars Squadrons XML (STEAM version ONLY) 4.2
Star Wars Squadrons XML plugin for 4.2
  1. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,171Coins
    Wagnard submitted a new resource:
    Star Wars Squadrons XML - Star Wars Squadrons XML plugin for v1.4
    • Winner Winner x 6
  2. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    @Wagnard I expected a magician to produce this plugin!
    Thanks! :thumbs
  3. ART FLY
    ART FLY Gettin' High on DIY :) Gold Contributor
    Bavarian State Theater, Decoration Stock Manager
    BAVARiA
    421Coins
    Hi, I just watched SCs Tutorial on CheatEngine.
    THANK YOU for doing that teadeaous job for us in finding the pointers and adding them to your plugin. It would take me a month to repeat that work. That is why I want to encourage you for updating your plugin anytime SW Squads gets an Update changing all the pointers again :grin I know I may only ask for that as a joke.
    It is awesome - you and SilentChill opened the door to Squads for the community :thumbs
    Next time I think I will get that CheatEnginePointerUpdatingStuff by myself. But for now YOU made it so much easier to start playing that impressive game in motion!
    hug:Yours ARTi
  4. kevinmarz
    kevinmarz Member
    346Coins
    This is awesome ..Thank you... everything's working just fine, until about halfway through a mission. My game crashes and so does Sims tools.. I've updated to the newest Sim tools and graphic drivers, still having the same problem.. curious to see if anybody else is having an issue thanks for any help...Edited......I deleted the App/data folder and started over ..seem too do the trick!!!
  5. Wagnard
    Wagnardsoft
    5,171Coins
    For information, Pointers survived latest patch (4.1) today :D
  6. ART FLY
    BAVARiA
    421Coins
    That is cool you checked it for us. I will try on the weekend. So it would have been bummer if they changed.
    Hey everybody have a silent 4th of Advent and cU around, cheers from BAVARiA, ARTi
  7. kevinmarz
    kevinmarz Member
    346Coins
    Game went dead...I reinstall anti-cheat... ran game..Than uninstall anti-cheat and turned off exe..again in out bound rules and it's still working....
  8. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    thank you.but... if uninstall and block game.exe and game launcher.exe, loose the online multiplayer funcionality right?
  9. kevinmarz
    kevinmarz Member
    346Coins
    Yes you lose the multiplayer functionality,but there's nothing stopping you from reversing the process and turning it back on...When you want to play Multiplayer....
  10. paulopsx2
    brasil
    647Coins
    Hum.. but MP its the best part... I using joystick plugin and its fine, anyway, thanks.
  11. paulopsx2
    brasil
    647Coins
    anyone knows how to disable only THROTTLE moves?
    for me, its so agressive and dont make any sense.
  12. MarkusB
    4,215Coins
    Just don‘t configure ‚surge‘ in SimTools. Wouldn‘t this solve it?
  13. paulopsx2
    brasil
    647Coins
    i will try it
  14. paulopsx2
    brasil
    647Coins
    yeap it works. in fact, surge movement is more agressive even if put at 20%.
    But for now its excellent and far better then joystick plugin
    thanks
  15. Piouzo
    Piouzo New Member
    - 141Coins
    Error when launching the game
  16. paulopsx2
    brasil
    647Coins
    you need to verify all files first.
    so, uninstall easy anti cheat
    finally, shutdown your internet ( in my case, shutdown because i dont want to block game.exe on firewall ).
  17. Piouzo
    Piouzo New Member
    - 141Coins
    Ok i had trouble uninstalling easy anti cheat. it is working now. Thank you
  18. Gintofufu
    Gintofufu New Member Gold Contributor
    - 123Coins
    thank you for the job, no other solution than uninstalling easy anti cheat?
  19. KydDynoMyte
    KydDynoMyte Fool's Gold Contributor
    RTP, NC
    50Coins
    You should be able to use a joystick plugin with EAC to be able to play online.
    Also it seems to work for a lot of us if you just rename the launcher exe something else and then rename the game exe to what the launcher name was to bypass EAC. Still only good for offline play though.
  20. BitPull
    BitPull Experimenter Gold Contributor
    Service Technician
    Germany, Michelstadt
    94Coins
    Hello, i can't get it working. Game manager is showing the game is running, Anti Cheat is uninstalled, both .exe are blocked. The Game can be played but there is no output to the simulator.
    Other Games are working well.
    Also Game manager is added to windows defender and allowed to do everything.
    Is this just for a special game version (steam/orgin/epic ... VR/nonVR) ?
    Thanks in advanced! :)
