Icy7CE
  1. Banfy
    Banfy FR/AU
    Australia
    299Coins
    DC motor, Arduino
    Hello
    I just upgraded my license to pro to use gamevibe
    I struggle to get rpm and turbulence tuned right
    can you/anyone pls share your settings (min/max volume, min/max frequency, min max tuning center value)
    i have a buttkicker 2
    thank you
  2. Banfy
    Banfy FR/AU
    Australia
    299Coins
    DC motor, Arduino
    i can use value you use from another flight sim as well, might be similar at the end...
  3. T R Para
    T R Para i make stuff up
    Cincinnati, Oh
    2,446Coins
    AC motor, 6DOF
    @Banfy I no longer use Game Vibe. It was ok but left a lot to be desired. What I found works best for me is pretty simple. I just use the sound from the game itself. My setup is a Bluetooth audio receiver which feeds into my 300watt subwoofer amplifier and then into the Clark Synthesis transducer. The computer has to be set up for Bluetooth and enabled in the audio settings. There are other ways to get the audio to your buttkicker, I just chose the wireless route.
    The amplifier should filter out any of the higher frequency audio.
    It was the best solution for me in both FS2020 and NL2.
    BTW I have switched to Pt Mover software to run my 6dof .
    Like you said "I struggle to get rpm and turbulence tuned right".
    That is what I found too.:):):)
    Set up:..
    Bash 300S Digital Subwoofer Plate Amplifier 300W RMS
    Clark Synthesis TST239 Silver Tactile Transducer Bass Shaker
    Echo Dot (3rd Gen) - Smart speaker with Alexa
  4. SeatTime
    Agree, I have always driven my buttkicker from my sound card, especially for games like NL2. Simple setup - works.
  5. ivan jack
    ivan jack Member
    412Coins
    My pc can deliver ultra performance on the game , I have smooth 60fps on ultra settings without motion , but when I'm running it with motion I have fps drops and stuttering in menu screen and game, barely getting 45 fps . what goes wrong?
    My PC specs:
    i5 9600k
    32gb Ram
    gtx 1660 ti
    2xAdata XPG Gammix S11 PRO M2
    Thank you!
  6. Icy7CE
    Icy7CE Active Member
    USA
    2,896Coins
    There's a trade-off between the rate of motion data transmission and the FPS of the game. You can try turning down the motion data rate, which by default is 100 Hz, by editing the config file in AppData\Local\SimTools\MFS2020. If you make this too low, the motion will be choppy, so you'll have to find a good balance.
    • Informative Informative x 3
  7. ivan jack
    ivan jack Member
    412Coins
    Thank you so much! I will try that :D
  8. EICHELBERGER Robin
    EICHELBERGER Robin Ayshel
    Piloting Plane
    - 48Coins
    Got the same problem, Thank you ! I'm gonna try that too !
  9. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    anyones knows how to use gamedash and vibes?
    motion its ok, but no dashs or vibes !
    153,848Coins
    +11,152 / 57 / -2
    Can you please post pictures of all of your GameDash and GameVive settings, that way @Icy7CE may be able to advise.
  11. paulopsx2
    brasil
    647Coins
    It works. I download MSFS SDK, and use SIMCONNECT.DLL from there :)
    and then patch again, and dash appears. thanks
  12. paulopsx2
    brasil
    647Coins
    if anyones needs this file, just pick up here. its original, free and recent ( 23 dec 2020 last update )
    • Useful Useful x 2
  13. paulopsx2
    brasil
    647Coins
    You need to buy 250 points in shop coins.
    153,848Coins
    +11,152 / 57 / -2
    The FAQs cover common questions, including plugin access option: https://www.xsimulator.net/community/faq/coins-and-how-to-download-plugins.2/
    The demo version of SimTools comes packed with the fully functional plugin for Live For Speed, specifically for testing purposes, and is not time limited in any way.
    Spamming the forum for coins is contrary to the Forum Rules and will result in a ban: https://www.xsimulator.net/community/threads/forum-rules.9527/
    153,848Coins
    +11,152 / 57 / -2
    You can choose to use SimTools or an alternative such as FlyPT, whatever works for you.
    The exploitation of SimTools and the Xsimulator.net community by commercial interests is what happened, and resulted in the necessity of strict licensing: https://www.xsimulator.net/community/threads/kickstarter-t1000-2-3-4-5-motion.6967/#post-79894
  16. jaynnc
    jaynnc New Member
    - 11Coins
    3DOF, Motion platform
    Does msfs 2020 and simtools implement heave as in feeling G-force when there is turbulence
    153,848Coins
    +11,152 / 57 / -2
    These are the listed supported outputs, which includes heave: https://www.xsimulator.net/community/marketplace/microsoft-flight-simulator-2020-plugin.246/
    Motion data: Roll, pitch, yaw, heave, sway, surge, roll rate, pitch rate, yaw rate
    GameDash data: RPM (engine 1, propeller 1, engine 2, propeller 2, engine 3, propeller 3, engine 4, propeller 4), speed, altitude, latitude, longitude, flaps (left trailing edge, right trailing edge, left leading edge, right leading edge), landing gear, stall warning, overspeed warning, on ground
    GameVibe data: RPM, turbulence, flaps, landing gear, road detail, collision L/R, collision F/B
  18. jaynnc
    jaynnc New Member
    - 11Coins
    Maybe I'm doing something wrong with the settings but I really don't feel any movement when the plane is moving on the airplane tarp or runway...is this normal
    153,848Coins
    +11,152 / 57 / -2
    Also see these tips on how to refine a motion profile, initially doing each axis individually: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  20. jaynnc
    jaynnc New Member
    - 11Coins
