DIY Linear Actuator design
Discussion in 'Motor actuators and drivers' started by wannabeaflyer2, Mar 5, 2016.
  1. SeatTime
    Your time/money so the decision is always yours.
  2. yondwangmms
    yondwangmms Member
    - 149Coins
    I mean, if there's no big performance gap between the two solutions, why not use a lower cost one? But because I have no comparison, I don't know how to choose.
  3. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    3DOF, DC motor, Arduino, 6DOF
    Just choose. In a few months, you will want to redo it all again anyway. All sim makers are like that.
    • Agree Agree x 3
  4. hannibal
    hannibal Active Member
    4,491Coins
    i am going thru this pain!
  5. Arta Yasa
    Arta Yasa Member
    824Coins
    wow, that's very good, in my country Indonesia a tool like this is very expensive, if you send it from china don't know how,, Lol
  6. Arta Yasa
    Arta Yasa Member
    824Coins
    I really appreciate your project sir. what about the power of the nema 23 stepper motor?? have you tested it?? i have read found no comparison between nema 23 and my1016. in my country these two dc motors are still easy to find at reasonable prices lol. and whether you can use a ballscrew with a screw length of 150mm travel 110mm ( length nut 40mm) I want to try to make 2 dof, or if possible for 4 dof sir. If that's possible, I'll immediately buy the ballscrew, because it's in a used goods warehouse. confused whether to use nema 23 or motor scooter my1016 or my6812. Thank you sir. Or someone can answer my question
  7. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    wow i like this a lot please do update us with the final product and parts and pricing as this looks like a future project for me once i become more knowledgeable in this science of motion rig lol.
  8. sci666
    1,220Coins
    mh nice work for the diy linear actuators ... is there a need for the end switches if i use standard 12v motors plus a hall sensor ?
  9. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    I don't know what exactly a hall sensor is, but limit switches are never a bad idea. Not having them IS a bad idea.
  10. sci666
    1,220Coins
    just see it yet, you got also my1016 motors for your first design ...
    so in the future i can do a similar design to yours ... its a good starting point ;D
    i have a question, what was the last revision of your DC Motor version ?
    only 1 hall sensor mounted in parallel to the motor shaft with a belt ?
    did you use end stops ? do you have the arduino code and the partslist in your archive ;D
  11. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,110Coins
    This build is for me :) I can't understand this stepper motors and it's controllers. Good old smc3 :) how u connect this micro switches? To power off?
