Question Simtools Setup with Dimension Engineering’s Kangaroo
Discussion in 'DIY Motion Simulator Projects' started by David Harbour, Dec 26, 2020.
  1. David Harbour
    David Harbour Member
    Surrey, UK
    479Coins
    2DOF, 3DOF, Motion platform
    I would be very grateful if any one could help with a setup problem with Simtools.
    I have recently upgraded my simulator to use a different type of position sensor to control my motors position, and within DEScribe I managed to complete a limit switch tune after the tune I set the BitsPerSec to 115200 and tried to connect to Simtools so far I have been unable to to get the motors to move in the output testing within game engine.
    I have setup the Interface with all the parameter's, although in the Pre-sets dialogue box it would not show the name of my pre-set and the file seamed to save ok
    on reading the documentation i have tried output bit ranges 12 & 16 with no effect, and i was connecting through a Silicon Labs CP210x UART on com 3 this is attached to the Kangaroo.
    at this stage i am at a loss if anyone can help i would be very grateful.
    I have enclosed some pictures of my setup for reference.
    Merry Christmas to all. Axis Assignments.PNG com output 3.PNG Simtools  Interface 1.PNG DEScribe.PNG
    153,986Coins
    +11,162 / 57 / -2
  3. David Harbour
    Surrey, UK
    479Coins
    Hi noorbeast, thanks for the reply I have been reading the manual possibility I might not have taken it all in, will also look at the manual in the link.
    thanks
  4. David Harbour
    Surrey, UK
    479Coins
    HI noorbeast, thank you for putting me back on track I can see the error in the code Interface - Output, i did not type it in but copied pasted the code, in future i will double check the code.
    Thanks again.
