SFX 100 push pull mod with 3D printed parts
Discussion in 'Motor actuators and drivers' started by wingert, Oct 26, 2020.
  1. wingert
    wingert Active Member
    666Coins
    4DOF
  2. cfischer
    Colorado
    2,752Coins
    Hardcore. Hope it holds.
    If it doesn't I've got pictures in my build thread of a simple solution to push/pull with a welder if you can get your hands on one. Gives room for a lot more travel too.
  3. wingert
    666Coins
    4DOF
    the aim was to find a solution with little effort, easy for everyboy without a lathe, welding and metal machining,
    very surprised how tight it fits.
  4. yondwangmms
    yondwangmms Member
    - 149Coins
    I look silly! But I did not understand what is the purpose of this new type of slider?
  5. wingert
    666Coins
    4DOF
    it has through boring for attachment a clamping attachment
  6. yondwangmms
    yondwangmms Member
    - 149Coins
    How much stretch can it withstand? The original sfx100 has only thrust but no tension, and cannot be used on the fifth axis of the horizontal axis. If your design pull is large enough, it can be used on the horizontal pull shaft, which is great!
  7. wingert
    666Coins
    4DOF
    choose the version with the metal collar (28/48mm) enlarged to 30mm that only works durable.
