Wagnard
Elite Dangerous Horizons/Odyssey Plugin (XML edition) 4.2.0.2 pointer update
  1. shaffy
    shaffy New Member
    - 494Coins
    hi,
    thanks for your work Wagnard.
    Downloaded, unpatch in admin mode, update with dragging and repactch on admin several times, still no motion in ED (and no values in tuning center).
    Is the plugin still working on dec, 28 ?
  2. kev b
    kev b Active Member
    Academic Lecturer - Electrical Engineering
    Swindon, UK
    939Coins
    3DOF, Arduino, Motion platform, 6DOF
    Hi - I can offer some help here. Yes, the current plugin works very well.
    From your posting I assume you have had a plugin working for motion before?
    Try the following;
    when you have unpatched a plugin and before re-patching the new one - run ED for a few mins and fly your ship about in all axis then close ED.
    Update your plugin using 'plugin updater'. Then re-patch it in 'game manager'.
    Start game engine and ED. Make sure the indicators show blue in game manager and game engine to show all is patched ok and running your ED profile in both. Use tuning centre to check/adjust if req'd.
    Alternatively (and the way I always update an existing patch for ED) is to just change the data in the XML file on your pc to the same data as in the updated XML file posted by mr Wagnard (I just cut and paste it in). Gets the motion up and running again in minutes (and keeps all your previous other settings intact).
  3. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,123Coins
    Pointers seems all good here too.
  4. shaffy
    shaffy New Member
    - 494Coins
    thanks to Kev B and Wagnard;
    Found my problem, my simtools version was definitively too old.
    Just uninstall simtools completely, reinstall last (2.5.1) and repatch like normal procedure, motion works instantly.
    Thanks for support here :)
  5. kev b
    kev b Active Member
    Swindon, UK
    939Coins
    Noooooo! -todays ED 'micro' update has made the motion cease! @Wagnard - are you busy at the moment?
  6. Wagnard
    Wagnardsoft
    5,123Coins
    I'm on it !
  7. Wagnard
    Wagnardsoft
    5,123Coins
    Latest pointers for today patch.
  8. Wagnard
    Wagnardsoft
    5,123Coins
  9. kev b
    kev b Active Member
    Swindon, UK
    939Coins
    checking it out now - quick work @Wagnard
    :thumbs
    update: ALL good again - just a single hex digit change too - lol
  10. George Dobransky
    Hungary
    - 43Coins
    THX AGAIN!
    works well!
  11. Wagnard
    Wagnardsoft
    5,123Coins
    Game got broken again this morning, currently fixing it...
  12. Wagnard
    Wagnardsoft
    5,123Coins
    Latest pointers for 29Jan patch
  13. Wagnard
    Wagnardsoft
    5,123Coins
  14. kev b
    kev b Active Member
    Swindon, UK
    939Coins
    Nice one @Wagnard . Just turned pc on after a busy day at work to find ED update required (sheesh!!). Just downloading update now and will update the xml again. Thanks for the quick turnaround.
  15. Wagnard
    Wagnardsoft
    5,123Coins
    No problem, again 1 digit changed.
  16. Mechromancer
    434Coins
    Man, haven't fired up ED since the scamdemic started.
    Gonna have to dl the update and go for a ride tonight! :D
  17. Wagnard
    Wagnardsoft
    5,123Coins
    I'm on the elite patch already folks!
    Done
    • Winner Winner x 4
  18. kev b
    kev b Active Member
    Swindon, UK
    939Coins
    Nice one @Wagnard . I'll give it a try out in the morning. Quick work (as usual hug:)
  19. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    3DOF, DC motor, Arduino, 6DOF
    I tested it, it worked fine. Did not test the vehicle.
    But I was quite sad to see that the game plugin does not work with Odyssey.
  20. kev b
    kev b Active Member
    Swindon, UK
    939Coins
    Odyssey is a different game so likely very different memory locations. If FD history stays true there will likely be many more updates/patches to EDO so simply won't be worth focussing on getting motion for that anytime soon. Personally I don't own EDO - yet, by may look at getting it when it is in a better state.
    Right now just happy that EDH is up and running with motion again.
