Showroom My Diy 2dof RC test then 2dof wiper motor diary
Discussion in 'DIY Motion Simulator Projects' started by Krzysztof Dej, Jan 1, 2021.
  1. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
  2. Krzysztof Dej
    Poland
    1,100Coins
    I find this yt film maybe this will be good for me it's step by step
  3. Krzysztof Dej
    Poland
    1,100Coins
    Can I do this in pt mover or only SIM tools?
  4. Krzysztof Dej
    Poland
    1,100Coins
    Wire is no problem i have Diy shifter and handbrake. I'm afraid of configuration
  5. Krzysztof Dej
    Poland
    1,100Coins
    Ok I have problem with configuration
    I download RC model files but can't install preset i have white config manually but noting happened can someone help me?
  6. Krzysztof Dej
    Poland
    1,100Coins
    My settings?
  7. Krzysztof Dej
    Poland
    1,100Coins
    Yeas it's working i will posty fight later no time now but first step are made
  8. Krzysztof Dej
    Poland
    1,100Coins
  9. Krzysztof Dej
    Poland
    1,100Coins
    This was my problem i have to add a letter for axis name
  10. Krzysztof Dej
    Poland
    1,100Coins
    Ok not much time but thing r getting better
    my config
  11. Krzysztof Dej
    Poland
    1,100Coins
    ...and results everythings going now smooth . Next i try install game and try how this works
  12. Krzysztof Dej
    Poland
    1,100Coins
    My testing platform. Tomarrow I will rec some testing films. Important to start lfs without patching first because game must create some important files first
  13. Krzysztof Dej
    Poland
    1,100Coins
    My test
  14. Krzysztof Dej
    Poland
    1,100Coins
    Ok all works. Now I must find how put UDP really to simhub to my bassshaker and shakeit work parallel and then choose what to do next : platform or belt tensioner
    Tnx for resources to @eaorobbie
  15. Krzysztof Dej
    Poland
    1,100Coins
    Any advice what power source for wiper motors? What wiper motor is the best choice?
    @noorbeast
  16. 17Nico17
    17Nico17 New Member
    Royan
    172Coins
    Hi!! You can go on my topic, if you read you will have good clues of what you can choose or not for your motors and power supply. ;)
    My post is called Home Made 2 dof simulator. It is 4th or 5th on this part of the forum
    Good luck :)
    153,890Coins
    +11,154 / 57 / -2
  18. Krzysztof Dej
    Poland
    1,100Coins
    Maybe someone can help me
    I gave shakeit and bassshaker in simhub and this doesn't work with lfs patched by simtools
    I have lfs config file and recommend settings by simhub
    153,890Coins
    +11,154 / 57 / -2
  20. Krzysztof Dej
    Poland
    1,100Coins
    Hi I don't understand it. Maybe the technikal language barier i have something like that and bassshaker and shakeit working on simtools port but sim tool doesn't work
    Any idea?
