My 2DOF rig
Discussion in 'DIY Motion Simulator Projects' started by drzmat, Dec 29, 2020.
  1. noorbeast
    153,716Coins
    Try a lower Tuning Center value for sway and roll, try 3-4 and tweak from there.
    Temporarily disable axis by setting 0% in Axis Assignments, or alternatively set the Axis temporarily to -
  2. drzmat
    drzmat Member
    184Coins
    I was looking at the FAQ #228 and i was wondering what they meant by :
    "Temporarily disable surge by setting is allocation to 0, that leave the Axis Allocation % in place so you can easily re-enable it."
    153,716Coins
    It should say set the Axis temporarily to - rather than 0, I will edit that to correct it.
  4. drzmat
    drzmat Member
    184Coins
    That make sense!
    Thanks Noorbeast!
  5. drzmat
    drzmat Member
    184Coins
    Hi guys, i have trouble tuning "heave" force on my rig, i just cant feel it in project cars 2 even with a pretty big value.
    I tried to run over curbs and even jump over them, not much motion happening.
    I am not even sure my motor rotation is ok for that force since i dont know how to test it.
    Any help would be appreciated.
    153,716Coins
    You likely need a smaller TC value, in some games less than 1, so try something like 0.5 and you should feel it.
    But a curb is more than heave, it includes pitch and roll as well.
    I use the bumpy bits of Monza in Assetto Corsa to tune heave,the track surface visually looks flat but some bits of it are quite bumpy.
  7. drzmat
    drzmat Member
    184Coins
    Ill try this thanks!
  8. absyfadhel1
    absyfadhel1 Active Member
    bahrain
    556Coins
    Could you make video for how to use tunning center...that FAQ didnt helped me
    153,716Coins
  10. Skuldi
    Skuldi Member Gold Contributor
    Germany NRW
    265Coins
    You can´t simulate heave with a 2dof rig. You need something like a 4DOF that can raise your rig up and down. When the car goes airborn, your rig will do almost nothing, but with an nice roll and pitch setting, you feel the landing.
  11. Sam Neall
    Sam Neall Member
    84Coins
    This is a nice and simplistic build. One thing you could consider is adding a metal bar where the motor arm connects to extend the distance from the center. This will decrease movement in exchange for less force exerted on the motor.
  12. drzmat
    drzmat Member
    184Coins
    Hi Sam, i am interested can you elaborate on this?
    I am not sure i understand where to put that metal bar?
    Thanks!
  13. Sam Neall
    Sam Neall Member
    84Coins
    No problem. As you can see in this picture, you can put the point of contact to the motor out farther from the center of the platform. This fixed the issue I had with one motor going down when no power was applied but it might not work for you due to your motor position. image.jpg
  14. drzmat
    drzmat Member
    184Coins
    I think i may look into a shorter lever ctc since it seems to have a bigger impact looking at simcalc....
  15. RacingMat
    21,081Coins
    @drzmat finally did you use the pololu dual vnh5019 instead of motomonster shield?
