Arduiono 6DOF simulator
Discussion in 'New users start here - FAQ' started by warichu1, Dec 16, 2020.
  1. warichu1
    warichu1 New Member
    189Coins
    I am a newbe here doing my final project. I want to use arduino mega for the positioning and the inverse kinematics and hoping to use SImtools for extraction and conversion. X-Sim is so hard to understand. ANybody with the way to go for setups?
    here is my adopted arduino code
    #include <Servo.h>
    //MIN and MAX PWM pulse sizes of Servos(Parallax 900-00005)
    #define MAX 2250
    #define MIN 750
    //Positions of servos mounted in opposite direction
    #define INV1 0
    #define INV2 2
    #define INV3 4
    //constants for computation of positions of connection points
    #define pi 3.14159
    #define deg2rad 180/pi
    #define deg30 pi/6
    //Array of servo objects
    Servo servo[6];
    //Zero positions of servos, in this positions their arms are perfectly horizontal, in us
    static int zero[6]={1500,1500,1500,1500,1500,1500};
    //In this array is stored requested position for platform - x,y,z,rot(x),rot(y),rot(z)
    static float arr[6]={0,0,0, radians(0),radians(0),radians(0)};
    //Actual degree of rotation of all servo arms, they start at 0 - horizontal, used to reduce
    //complexity of calculating new degree of rotation
    static float theta_a[6]={0.0,0.0,0.0, 0.0,0.0,0.0};
    //Array of current servo positions in us
    static int servo_pos[6];
    //rotation of servo arms in respect to axis x
    const float beta[] = {0, pi, -(2 * pi/3), (pi/3), (2 * pi/3), -(pi/3)},
    //maximum servo positions, 0 is horizontal position
    servo_min=radians(-70),servo_max=radians(70),
    //servo_mult - multiplier used for conversion radians->servo pulse in us
    //L1-effective length of servo arm, L2 - length of base and platform connecting arm
    //z_home - height of platform above base, 0 is height of servo arms
    servo_mult=400/(pi/4), L1 = 1.48, L2 = 8.67, z_home = 7.48;
    //RD distance from center of platform to attachment points (arm attachment point)
    //RD distance from center of base to center of servo rotation points (servo axis)
    //theta_p-angle between two servo axis points,
    //theta_r - between platform attachment points
    //theta_angle-helper variable
    //p[][]=x y values for servo rotation points
    //re[]{}=x y z values of platform attachment points positions
    //equations used for p and re will affect postion of X axis, they can be changed to achieve
    //specific X axis position
    const float RD = 5.51,PD = 5.51,theta_p = radians(70),
    theta_angle=radians(6), theta_r = radians(25),
    p[2][6]={
    -3.15,3.15,
    5.12,2.17,
    -2.17,-5.12
    4.33,4.33,
    0.59,-4.33,
    -4.33,0.59
    re[3][6] = {
    -3.94,3.94,
    5.12,1.18,
    -1.18,-5.12,
    3.54, 3.54,
    1.38,-5.31,
    -5.31,1.38,
    0,0,0,0,0,0
    //arrays used for servo rotation calculation
    //H[]-center position of platform can be moved with respect to base, this is
    //translation vector representing this move
    static float M[3][3], rxp[3][6], T[3], H[3] = {0,0,z_home};
    void setup(){
    //attachment of servos to PWM digital pins of arduino
    servo[0].attach(9, MIN, MAX);
    servo[1].attach(3, MIN, MAX);
    servo[2].attach(5, MIN, MAX);
    servo[3].attach(11, MIN, MAX);
    servo[4].attach(6, MIN, MAX);
    servo[5].attach(10, MIN, MAX);
    //begin of serial communication
    Serial.begin(9600);
    //reminder to include lines for centering platform
    //putting into base position
    setPos(arr);
    delay(3000);
    //function calculating needed servo rotation value
    float getAlpha(int *i){
    static int n;
    static float th=0;
    static float q[3], dl[3], dl2;
    double min=servo_min;
    double max=servo_max;
    n=0;
    th=theta_a[*i];
    while(n<20){
    //calculation of position of base attachment point (point on servo arm where is leg connected)
    q[0] = L1*cos(th)*cos(beta[*i]) + p[0][*i];
    q[1] = L1*cos(th)*sin(beta[*i]) + p[1][*i];
    q[2] = L1*sin(th);
    //calculation of distance between according platform attachment point and base attachment point
    dl[0] = rxp[0][*i] - q[0];
    dl[1] = rxp[1][*i] - q[1];
    dl[2] = rxp[2][*i] - q[2];
    dl2 = sqrt(dl[0]*dl[0] + dl[1]*dl[1] + dl[2]*dl[2]);
    //if this distance is the same as leg length, value of theta_a is correct, we return it
    if(abs(L2-dl2)<0.01){
    return th;
    //if not, we split the searched space in half, then try next value
    if(dl2<L2){
    max=th;
    }else{
    min=th;
    n+=1;
    if(max==servo_min || min==servo_max){
    return th;
    th = min+(max-min)/2;
    return th;
    //function calculating rotation matrix
    void getmatrix(float pe[])
    float psi=pe[5];
    float theta=pe[4];
    float phi=pe[3];
    M[0][0] = cos(psi)*cos(theta);
    M[1][0] = -sin(psi)*cos(phi)+cos(psi)*sin(theta)*sin(phi);
    M[2][0] = sin(psi)*sin(phi)+cos(psi)*cos(phi)*sin(theta);
    M[0][1] = sin(psi)*cos(theta);
    M[1][1] = cos(psi)*cos(phi)+sin(psi)*sin(theta)*sin(phi);
    M[2][1] = -cos(psi)*sin(phi)+sin(psi)*sin(theta)*cos(phi);
    M[0][2] = -sin(theta);
    M[1][2] = cos(theta)*sin(phi);
    M[2][2] = cos(theta)*cos(phi);
    //calculates wanted position of platform attachment points using calculated rotation matrix
    //and translation vector
    void getrxp(float pe[])
    for(int i=0;i<6;i++){
    rxp[0] = T[0]+M[0][0]*(re[0])+M[0][1]*(re[1])+M[0][2]*(re[2]);
    rxp[1] = T[1]+M[1][0]*(re[0])+M[1][1]*(re[1])+M[1][2]*(re[2]);
    rxp[2] = T[2]+M[2][0]*(re[0])+M[2][1]*(re[1])+M[2][2]*(re[2]);
    //function calculating translation vector - desired move vector + home translation vector
    void getT(float pe[])
    T[0] = pe[0]+H[0];
    T[1] = pe[1]+H[1];
    T[2] = pe[2]+H[2];
    unsigned char setPos(float pe[]){
    unsigned char errorcount;
    errorcount=0;
    for(int i = 0; i < 6; i++)
    getT(pe);
    getmatrix(pe);
    getrxp(pe);
    theta_a=getAlpha(&i);
    if(i==INV1||i==INV2||i==INV3){
    servo_pos = constrain(zero - (theta_a)*servo_mult, MIN,MAX);
    else{
    servo_pos = constrain(zero + (theta_a)*servo_mult, MIN,MAX);
    if(theta_a==servo_min||theta_a[i]==servo_max||servo_pos[i]==MIN||servo_pos[i]==MAX){
    errorcount++;
    servo[i].writeMicroseconds(servo_pos[i]);
    return errorcount;
    //main control loop, obtain requested action from serial connection, then execute it
    void loop()
    if(Serial.available()>0){
    int input=Serial.read();
    //action to change position of platform, obtain 6 values representing desired position
    long kk;
    while(Serial.available()<4){
    kk=(long)Serial.read();
    kk=kk+(Serial.read()<<8);
    kk=kk+(Serial.read()<<16);
    kk=kk+(Serial.read()<<24);
    if(i<3){
    arr[i]=(kk/100)/25.4;
    }else{
    arr[i]=radians(kk/100.0);
    Serial.write(setPos(arr));
    Serial.flush();
    //return current position of platform
    retPos();
    void retPos(){
    long val;
    if(i<3){
    val=(long)(arr[i]*100*25.4);
    }else{
    val=(long)(arr[i]*100*deg2rad);
    Serial.write(val);
    Serial.write((val>>8));
    Serial.write((val>>16));
    Serial.write((val>>24));
    Serial.flush();
    }[/i][/i][/i][/i][/i][/i][/i][/i][/i]
  2. warichu1
    warichu1 New Member
    189Coins
    I am now using Arduino UNO and here are my setups
    any insights please?
    152,003Coins
    +11,061 / 56 / -2
    You need to post all relevant information, such as Interface Settings, plus what you have and have not done, for Example Output Testing needs to work as expected before doing anything else.
    Most use @eaorobbie 's RC code, see the post here, which also includes tips for configuring it with SimTools 2: https://www.xsimulator.net/community/threads/2dof-simulator-servo-model.6851/#post-77270
    LFS needs to be run before it is patched for motion: https://www.xsimulator.net/communit...run-in-first-person-mode-before-patching.365/
    Grab a copy of the SimTools manual here: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    And see the tuning tips: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  4. Gadget999
    12,035Coins
    Use the smc3 code
    I use 3 nanos each one controls 2 actuators
    It works great !
    I have built a single board that can control 6 motors, not found time to test it
  5. warichu1
    warichu1 New Member
    189Coins
    My budget is tight and I have now week to finalize. I have one Uno. I have done the inverse kinematics as shown in the code. i Just need corrections on the code, and the simtools setup. or if anybody has used x-sim, the better
  6. warichu1
    warichu1 New Member
    189Coins
    okay let me send my interface setup and the axis setup as well. Please assist me get on the right track. Note, the output testing also not working. What might be the problem?
    getting data to the engine too
  7. Gadget999
    12,035Coins
    The Uno does not have enough pins to run a 6dof sim
  8. Gadget999
    12,035Coins
    Does your code use pid control ?
    How does it compensate for the cog of the driver ?
    I think you can use simtools to convert rotary motion to linear motion
    152,003Coins
    +11,061 / 56 / -2
    Interface Settings should be formatted like this, with an upper case<Axis1a>
    Don't bother with LFS until Output Testing works as expected.
  10. warichu1
    warichu1 New Member
    189Coins
    what do you mean? I have enough PWM pins
  11. warichu1
    warichu1 New Member
    189Coins
    let me try it out. are the axis okay?
  12. warichu1
    warichu1 New Member
    189Coins
    I intend to incorporate PID. Its in the pipeline. for now I just need to have some movements.
  13. Gadget999
    12,035Coins
    you will need analogue feedback pin, pwm pin and direction pin for each motor
  14. warichu1
    warichu1 New Member
    189Coins
