Starting with my SMC3 Arduino 3DOF with problems!!!
Discussion in 'DIY Motion Simulator Projects' started by Gepsi, Jan 15, 2016.
complete SMC3 diagram for MODE1
  1. a diagram... complete!!!! 3 motors!!!
    66.7%
  2. any
    33.3%
Multiple votes are allowed.
  1. SeatTime
    Ditto :).
  2. SeatTime
    Ditto 'again' :).
  3. marcosrobert
    marcosrobert New Member
    Design Grafico
    Sao Paulo - Brasil
    253Coins
    I have the potentiometers in the engines and even so the green line does not follow the blue line
    153,709Coins
  5. marcosrobert
    Design Grafico
    Sao Paulo - Brasil
    253Coins
    - Yes. I configured the code for Mode 2 as needed
    - I checked the connections and this is according to the diagram
    153,709Coins
    Have you connected the pots to the motors?
  7. marcosrobert
    Design Grafico
    Sao Paulo - Brasil
    253Coins
    I connected the pot following the diagram.
    Is correct?
    When I turn the pot, the green line goes up or down,
    indicating that the potentiometer is working
  8. marcosrobert
    Design Grafico
    Sao Paulo - Brasil
    253Coins
    153,709Coins
  10. Christian Doehl
    Christian Doehl Member Gold Contributor
    Germany - Bavaria
    702Coins
    Just for understanding: When the motor turns it has to turn the pot as well as this is the feedback for the motor position. When th motor moves the lever it also turns the pot and the resistance value ist the feedback for the Arduino. So as Noorbeast already mentioned you have to connect the pot to the motor, in this case connect does not mean wiring but mounting. And keep in mind that the pot housing has to be mounted to the frame or something else as otherwise the motor turns everything and the resistance will not be changed.
  11. marcosrobert
    Design Grafico
    Sao Paulo - Brasil
    253Coins
    I will connect the potentiometer to the motor. Thank you very much for the clarifications
  12. hooshang
    hooshang Active Member
    275Coins
    perfect cockpit frame
  13. marcosrobert
    Design Grafico
    Sao Paulo - Brasil
    253Coins
    I followed the guidance and mounted the potentiometer on the engine.
    On the SMC3 the green line does not yet follow the blue line
    What can it be?
  14. marcosrobert
    Design Grafico
    Sao Paulo - Brasil
    253Coins
    I changed the potentiometer and got this result in SMC3
  15. Christian Doehl
    Germany - Bavaria
    702Coins
    Just guessing but your pot looks like a multiturn pot, means it needs multiple turns to reach limits, in this case you may need something like a gearbox. A big gear on motor shaft and a small one on pot. Not sure thats the rootcause but a possibility. In my opinion your mount is for max 360 degree pot.
    BR
    Chris
  16. marcosrobert
    Design Grafico
    Sao Paulo - Brasil
    253Coins
  17. Christian Doehl
    Germany - Bavaria
    702Coins
  18. marcosrobert
    Design Grafico
    Sao Paulo - Brasil
    253Coins
