Question Kangaroo vibrating and shaking violently .
Discussion in 'DIY Motion Simulator Projects' started by David Harbour, Dec 27, 2020.
  1. David Harbour
    David Harbour Member
    Surrey, UK
    479Coins
    2DOF, 3DOF, Motion platform
    Hi can I ask anyone who has experience of the Dimension Engineering’s Kangaroo controller.
    The problem I am having is that the motors vibrate and shake violently in the downward motion and it is not so bad going in reverse generally ok I have tried this in simtools with the same effect .
    I have tried all the settings in DEScribe with no effect.
  2. Sam Neall
    Sam Neall Member
    84Coins
    This sounds like a SMC3 issue. Maybe try changing the baud rate. I have a Sabertooth which is also made by Dimension Engineering and I never had to configure anything on it. I had the same issue with the motor skipping when going down and I fixed it with changing the baud rate from 500000 to 115200.
  3. RacingMat
    21,006Coins
    did you use the autotune kangaroo function?
    what is your mechanical setup? some pics?
  4. David Harbour
    Surrey, UK
    479Coins
    Hi Sam
    thanks for the reply, at the time of writing I was having issues with Kangaroo controller and the sabertooth, without using the SMC Software although I have had issues since I decided not to use the Kangaroo Controller and went over to SMC.
    The problem I was having with the Kangaroo was severe oscillations in the downward motion that I could not get rid of, to the point the motors would lock up, this was more pronounced on the right motor.
    I have also tried SMC again with problems, I think the root cause is in the design and implementation of the hall sensors, my first attempt was using a pully system this seemed ok but i am getting to many errors so I am in the process my hall sensor mounting to be driven direct from the motor.
  5. David Harbour
    Surrey, UK
    479Coins
    Hi RaceingMat
    Thanks for your reply, I did use the autotune function and managed to get a successful tune using limit switches I tried this three times and it worked every time, the autotune that is.
    but after the tune in Simtools I had severe oscillations in the downward motion to the point the motors would lock up and i would need to reset the simulator.
    I think the root cause is in the design and implementation of the hall sensors, my first attempt was using a pully system this seemed ok but i am getting to many errors so I am in the process my hall sensor mounting to be driven direct from the motor, at this point to rewire my simulator to make this work.
  6. Sam Neall
    Sam Neall Member
    84Coins
    Oh ok. I have never used my motors in the DE software, to be honest I didn't know you could haha. I have had very similar problems to yours where a motor will oscillate when going one direction but move smooth the other direction. This was only prevalent in one motor for me and occurred after using the simulator for about a minute. The baud rate setting has been known to cause these really weird issues.
    I have my sensor direct driven, but I would experiment with the baud rate because your design could be fine. Try changing it to 115200 on the game engine and the Arduino code. Some off-brand Arduinos like the one I have cant handle 500000.
