6 DOF - Servos Motors 750W 90ST-M03520
Discussion in 'DIY Motion Simulator Projects' started by coyote, Oct 24, 2020.
  1. coyote
    coyote Member
    France - Yonne
    679Coins
    Finally, the ball joints arrived. I will be able to consider the rest ...:)
  2. Gadget999
    12,132Coins
    what ratio are your gearboxes ?
  3. coyote
    coyote Member
    France - Yonne
    679Coins
    hi,
    Gearboxes are 50:1 and motors are 2000tr/mn
  4. coyote
    coyote Member
    France - Yonne
    679Coins
    50 days after the order, receipt of the Output Shaft Coupler Connector. Use of the grinder, to obtain two solder connectors.
  5. yondwangmms
    yondwangmms Member
    - 148Coins
    This six-axis project looks great! Looking forward to seeing the effect video of your finished product!
  6. coyote
    coyote Member
    France - Yonne
    679Coins
  7. coyote
    coyote Member
    France - Yonne
    679Coins
    3D printing for high ball joint fixation test. IMG_20210105_205635.jpg IMG_20210105_205844.jpg
  8. coyote
    coyote Member
    France - Yonne
    679Coins
  9. coyote
    coyote Member
    France - Yonne
    679Coins
    Have a good day today.
    Cutting and welding for blank assembly of the platform.
  10. coyote
    coyote Member
    France - Yonne
    679Coins
    Support design for the positioning sensor.
  11. Gadget999
    12,132Coins
    It is used to index the motors ?
  12. coyote
    coyote Member
    France - Yonne
    679Coins
    No, just to detect the end stop for use with the Thanos board.
  13. coyote
    coyote Member
    France - Yonne
    679Coins
    The weekend advances.
    The base and high platform painting.
  14. coyote
    coyote Member
    France - Yonne
    679Coins
    Progress of the day :
    IMG_20210123_132815.jpg IMG_20210123_151050-r.jpg IMG_20210123_203246_1-r.jpg
    • Like Like x 7
  15. coyote
    coyote Member
    France - Yonne
    679Coins
    To be continued....
  16. coyote
    coyote Member
    France - Yonne
    679Coins
    We advance on the low voltage part and Thanos board.
  17. coyote
    coyote Member
    France - Yonne
    679Coins
    So, after the low voltage; the 220V part is planned to supply the motors.
  18. coyote
    coyote Member
    France - Yonne
    679Coins
    Does anyone use this type of driver? I'm looking to use the RS232 connection for the setup.
    I am looking for the configuration of the serial port; speed, baud etc ...
    I am also looking for the cable to use.
  19. Thanos
    Electronics Engineer
    2,907Coins
    These servos don't have serial interface. They have modbus for networking under industrial use...
    Use their panel to set their parameters...
    Thanos
  20. coyote
    coyote Member
    France - Yonne
    679Coins
    Mine are equipped with RS232 and Modbus. Indeed it is necessary to modify the parameters Pn064 to Pn067.
    Just need the cable now.
