Question HELP - Sim racing brake pedal with Arduino pressure sensor
Discussion in 'DIY peripherals' started by PUBWIE, Jan 14, 2021.
  1. PUBWIE
    PUBWIE New Member
    78Coins
    Does anyone know how to code an Arduino pro micro to read inputs from a brake pressure sensor?
    *No code on github
    Usually, one can get the code from Github, upload it to Arduino, and play. I have found codes for load cells, but nothing on pressure sensors and their process for calibrating.
    * No wiring guides to Arduino Pro micro
    - again, load cell wiring guides are available, but not much for pressure sensors.
    To have the Arduino micro read inputs from the pressure sensor to act as an in-game brake.
    Idea reference 1: Lebois P1 brake pedal DIY pressure sensor
    Idea reference 2: modify G29 brake pedal
    Any ideas, links to sites/ guides, please?
    - TIA
    Picture reference
    1)Lebois P1 brake pedal DIY pressure sensor
    2)modify G29 brake pedal + presure sensor
  2. Sieben
    Sieben Active Member
    2,241Coins
    Connects like a simple pot, and uses whatever software axis, that commonly used here, on your choice. Trying to reinvent a bike?
  3. noSaint
    noSaint New Member Gold Contributor
    160Coins
  4. Gadget999
    12,035Coins
    I made my own, the pressure sensor outputs 0-3.3 v
    So you use it as you would a pot
  5. noSaint
    160Coins
    I guess you map the voltage signal going into the Arduino and run the joystick code
  6. PUBWIE
    PUBWIE New Member
    78Coins
    Thanks for the feedback.
    Waiting on parts. I'll post my results when it gets done.
    Cheers :)
