My project 4 DOF
Discussion in 'DIY Motion Simulator Projects' started by Stouuf, Feb 25, 2018.
  1. Stouuf
    Stouuf Member
    399Coins
    4DOF
    I reconfirm, it still does not work
    I tried several times to uninstall / reinstall by downloading the new setup several times, restarting the pc but nothing helped
    Could someone help me?
    152,553Coins
    +11,087 / 56 / -2
  3. Stouuf
    Stouuf Member
    399Coins
    4DOF
    Yes, and since it didn't work, I also tried uninstallation with the help of another software but it still shows the same error ...
  4. Stouuf
    Stouuf Member
    399Coins
    4DOF
    I just tried an uninstall / reinstall with a PC restart between the 2, but it's always the same ...
    I copied the detail of the error message, does this speak to someone who could help me ?
    System.IO.FileNotFoundException: Could not load file or assembly 'Newtonsoft.Json, Version=7.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. Le fichier spécifié est introuvable.
    File name: 'Newtonsoft.Json, Version=7.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed'
    at ‍‍‫‪‮‌‬‭‫‪‭‭‏‌‪‮‍‫‪‭‬‏‌‬‮.‏‏‎‮‍‎‎‌‭‎‏‮‪‌‫‮‭‎‭‪‫‮(String , String , String , String )
    at ‪‪‪‎‬‬‍‭‎‭‬‎‬‮‏‬‎‌‪‎‌‫‌‮.‪‫‍‬‭‪‫‏‏‪‭‭‫‮‏‮(Object , EventArgs )
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.ButtonBase.WndProc(Message& m)
    at System.Windows.Forms.Button.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    AVT : la journalisation de liaison d'assembly est désactivée.
    Pour activer la journalisation des échecs de liaison d'assembly, attribuez la valeur 1 à la valeur de Registre [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD).
    Remarque : une certaine perte de performance est associée à l'enregistrement dans le journal des échecs de liaison d'assembly.
    Pour désactiver cette fonctionnalité, supprimez la valeur de Registre [HKLM\Software\Microsoft\Fusion!EnableLog].
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4300.0 built by: NET48REL1LAST_C
    SimTools_Registration
    Assembly Version: 0.2.4.0
    Win32 Version: 0.2.4.0
    CodeBase: file:///C:/Users/cuill/OneDrive/Desktop/Logiciel/Simulateur/SimTools_Registration.exe
    zQVptjPUWNsSFrVyhwpZSAGcucK
    Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    Win32 Version: 4.8.4270.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    Win32 Version: 4.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    System.Management
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    enabled.
    For example:
    <configuration>
    </configuration>
    152,553Coins
    +11,087 / 56 / -2
    Just a thought, uninstall SimTools, answer 'Yes' to 'Remove old files'.
    Temporarily turn off both firewall and antivirus, to ensure neither of them is interferring with the installation.
    Reinstall SimTools and test.
    Perhaps @yobuddy has further suggestions.
  6. yobuddy
    51,192Coins
    It's complaining about not finding a file that gets installed with simtools.
    Please look in the installation folder of simtools after the reinstall, and verify a file named "Newtonsoft.Json.dll" is present.
    It should be in the simtools installation folder.
    Chat soon,
  7. Stouuf
    Stouuf Member
    399Coins
    4DOF
    I just redo exactly what you said noorbeast without antivirus and firewall but still got the error message ...
    I checked, the "Newtonsoft.Json.dll" file is indeed present in the installation folder, I don't know what to do ... :(
    152,553Coins
    +11,087 / 56 / -2
    Do a clean download of the latest SimTools version: https://www.xsimulator.net/community/marketplace/motion-simulation-software-simtools.63/
    Make sure the computer is set to English Local: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
    Uninstall existing SimTools and answer 'Yes' to 'Remove old files'.
    Reinstall the newly downloaded SimTools and test.
  9. Stouuf
    Stouuf Member
    399Coins
    4DOF
    I just did exactly what you advised me to do, but nothing changes, I still get the same error message ... :eek:
    152,553Coins
    +11,087 / 56 / -2
    If you are doing a clean download and install, after wiping existing install, then it seems likely something on your system is messing with the install, any further ideas @yobuddy?
  11. yobuddy
    51,192Coins
  12. Stouuf
    Stouuf Member
    399Coins
    4DOF
    Hi all !
    Well, I tried everything you told me right after receiving your messages, nothing worked ...
    But I tried again today after a smooth launch of another software that got thrown every time (because of the firewall, anti-virus or other I don't know), and there SimTools accepted the activation of my license !!!!! :thumbs
    It's so cool, but in reality I don't know at all what has to change to make it work, I haven't done anything about it !! o_O But good, so much the better !!! :grin
    Thank you all for your responses hug:
  13. luu trung
    luu trung Member
    172Coins
    hi . i am also having a headache to make the center shaft anti-rotator with cardan joints. i see you have 3 anti-rotation holders that do the "heavy" axis up and down . i don't understand how the roll and pitch axis will tilt like when there is 1 bar in the middle. i use 3 motors
