2DOF for beginners
Discussion in 'DIY Motion Simulator Projects' started by Swiffty, Jan 20, 2021.
  1. Swiffty
    Swiffty New Member
    Slovakia
    22Coins
    Hi all, I have started to build a 2DOF, however I came to a problem when testing with motors... The issue is that the motors dont run when I turn the pot immediatelly, but roughly after a half of a turn on the pot. Also they turn only in one direction. Can anyone help/get some ideas of what could be wrong?
    I am using arduino uno, moto monster and 2 wiper motors. Loads of thanks
  2. noSaint
    noSaint New Member Gold Contributor
    160Coins
    Hi. Describe your setup a bit better.
    153,770Coins
    +11,149 / 57 / -2
  4. Swiffty
    Swiffty New Member
    Slovakia
    22Coins
    Here are some pics of the setup:
  5. zapata_h
    zapata_h Active Member
    España
    308Coins
    3DOF, AC motor, Arduino
    Have you checked that the potentiometer works correctly 0-5v?
  6. Swiffty
    Swiffty New Member
    Slovakia
    22Coins
    Yes, the pot is correct, hower i have found an cable that was burned, like whole and cut, so I changed it and it works, but not correctly... roll is ok, but pitch is the same, i have tried to change also the "red" button for opposite directions, but always the same as roll when I move the slider...
  7. Mattlekim
    Mattlekim Member
    - 5Coins
    I had the same problem on mine. No matter what way I turned the potentiometers the motor turned the same way. Tuned out to be a short and a bad 5v solder.
    Check your soldering / connections.
    Also you apply the voltage directly to the motor to test them out. I ended up doing that to make sure that wasn't the problem
