value1
Assetto Corsa Plugin 2.0.7.1
SimTools plugin for Assetto Corsa
  1. noorbeast
    152,265Coins
    +11,066 / 56 / -2
  2. value1
    15,041Coins
    You can find the Assetto Corsa Competizione plugin is here.
    A compilation of most of the available plugins is here.
  3. MENANDRO DALIDA JR
    MENANDRO DALIDA JR Member
    51Coins
    Hi Optical10,
    I have the same issues as yours, How did you patch correctly the AC? I did reinstall the AC, repatched the AC plugin, but still to no avail with "Game Running".
    Hope you can share the solutions.
    Thank you in advance.
    Menan :)
    152,265Coins
    +11,066 / 56 / -2
    Just checking, is there no data in the top row of the Tuning Center when AC is running in a race?
  5. MENANDRO DALIDA JR
    51Coins
    Hi Sir Noorbeast,
    Yes, at first there's no data. But now, finally has the movement. What I did is reset the tuning center, click the Capture Max Min, run the AC at least 1 lap, then the Sim Tools automatically indicates "Game Running" and the data's appeared at the tuning center.
    Thanks for the advice, keep Safe!
    Cheers :)
  6. long legs
    long legs Perfect Race is a perfect day
    teacher
    catalonia
    373Coins
    2DOF, SCN5, Motion platform
    Hello, I WILL try t'his method because I can't make motion with t'he latest update.
  7. MENANDRO DALIDA JR
    51Coins
    Sure
    let us know if it’s works also for you
  8. long legs
    teacher
    catalonia
    373Coins
    This afternoon i tried this method but the game engine crashes faster and can't open a tunning center before it crashes.
    It's strange because all other titles are working perfectly, including assetto corsa competizione.
    152,265Coins
    +11,066 / 56 / -2
    Assetto Corsa Competizione is built on a different engine.
    You can open the Tuning Center without the AC running and select AC in the Game Selected drop down bottom left. Can you please post a picture of the current settings.
    You can also try dropping the Intensity Level % in Game Manager -> Profile Editor
  10. long legs
    teacher
    catalonia
    373Coins
  11. long legs
    teacher
    catalonia
    373Coins
    It's very strange. When i start a race, im going to a task bar, touch the game engine icon, and suddently dessapear, stops and I try to open game engine another time, opens, but not dectect the game (axis assignements are not lock in blue). Sometimes Game manager appears blue detecting the game.
    152,265Coins
    +11,066 / 56 / -2
    Is the computer set to English Local: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
    When I suggested backing off the Intensity Level I had in mind something like 95-97%, just to ease any spikes.
    Are the any error warnings?
  13. long legs
    teacher
    catalonia
    373Coins
    I read something about framework 4.0 or similar but i don't know how to solve it. @yobuddy I think know about this issue from another simtools user.
    Thanks to all people in advance!!
  14. long legs
    teacher
    catalonia
    373Coins
  15. long legs
    teacher
    catalonia
    373Coins
    in this moment, in this menu, the game engine is death, and game manager detects the game. in the past, game manager detects the game before this menu, in a doble click in the desktop icon of the game.
  16. long legs
    teacher
    catalonia
    373Coins
    here a pictures of my setup. Game Running only when im racing, not at the biggining of the game. The game engine continues stoped and crashing. If i open it in the midle of the game, it can't recibe any virtual data.
    I try to erase a folderr App data in my documents, but all continues exacly.
    thanks
  17. long legs
    teacher
    catalonia
    373Coins
    Now update simtools to the last update, but nothing change. I have teamviewer if someone want to try assetto live again jajaj and will post the modifications and results.
  18. noorbeast
    152,265Coins
    +11,066 / 56 / -2
    Have you tried different USB cables and USB ports, as what you describe sounds like a disconnect.
  19. long legs
    teacher
    catalonia
    373Coins
    Hey friend!
    Im not trying to change differents Usb, because all the other titles working perfectly, and the Game engine working perfect, only crasch in assetto corsa.
    Is difficult to me change usb, because Dirt rally and some other titles loose the personal preferences like controls etc...
  20. long legs
    teacher
    catalonia
    373Coins
    today i tried to change the usb ports from my motion. The results are very very cathastrofics hahaha. My game engine was very unstable, crash when i started it, and can't manage any game.
    I decided to uninstall all the simtools from my computer, and do a clean install. I test with dirt rally and seems game engine stable, but i can't try with assetto corsa. Tomorrow I will test. It's an ugly job because i have to add a tunning center values for each game, and add all the axxis assignments.
    Tomorrow i will write here. Crossfingers please hahaha.
