FlyPT Mover 3.5.3
  1. alex928gt
    alex928gt Member
    397Coins
  2. alex928gt
    alex928gt Member
    397Coins
    Thanks @pmvcda. I'll give it a try.
    However this issue with speed is that... it's just speed. Meaning that when you jump on the throttle from a stop you'll get a weak signal because speed is at 0 whereas the acceleration value actually jumps.
    It's the issue with speed that has to be continuous - physically speaking - while acceleration is not and can jump.
  3. Dirty
    All the way up front.
    7,952Coins
    I have doubts that any static filter will achieve this effect. Btw, a "static" filter is one that has constant (static) filter parameters.
    Instead of asking "Which filter with which parameters do we need?" , maybe we need to ask the question: "How and when would the filter parameters need to change?"
  4. pmvcda
    15,384Coins
    So this is the result of considering only growing values with a basic washout (multiplier with .995):
    Not solving the issue... It's not so simple to make it.
    That's what I have right now.
    Acceleration, followed by releasing the pedal in DirtRally2 with acceleration
    If we put a slower washout, then that deceleration is completely ignored...
  5. pmvcda
    15,384Coins
    Here with bigger washout:
    Here with some brakes and accelerations. Seems like a spike filter....
    Maybe we should try with a spike filter.
  6. alex928gt
    alex928gt Member
    397Coins
    Thanks a lot @pmvcda but there is no emergency, don't feel any stress about this you are already providing great value to us all with Mover.
    You can take some time to think about it and also maybe do something else with your life meanwhile if you want to.
    Anyway, I believe the chart below that I provided earlier could be useful to help.
    Btw - sorry, another request - you could maybe add in the wave types in the source loop the wave that would be a square with pauses between positive and negative alternances, i.e. 0 for 250ms, X for 250ms, 0 for 250ms, -X for 250ms and so on.
    upload_2021-1-24_20-22-48.png `
    Thx
    Alex
  7. pmvcda
    15,384Coins
    You can achieve that wave with the superimposition of two:
    Add them in the pose
    152,051Coins
    +11,063 / 56 / -2
    Interesting discussion re gearshifts, so here is my take.
    As I have often said before in my view consideration needs to be given not just to the physics, but the subsequent constraint/restraint of the user, then in terms of motion simulation the effective exploitation of the weaknesses of human processing and perception within the design parameters of the rig.
    With respect to what happens in a gearshift I would suggest example simplification, so consider of a motorcycle, where it is more obvious.
    Unlike an aircraft acceleration is related to traction, and pitch, in a rear wheel drive, rotates around the back wheel, not the center of the vehicle. There is a transfer of mass to the rear, decompression of the front spring and compression of the rear spring. If it goes far enough it is called a wheel stand.
    With a gear shift you have a momentary decompression of the rear spring and compression of the front spring as the throttle is released and mass moves, and pitch pivots down through the rear wheel, then the whole shebang reverses again as the throttle is again applied.
    I am using a motorcycle as an example as it make explicit that you also need to take into account the constraint/restraint, or otherwise, of a user. On a bike the rider constraint is the grip on the handle bars, the contact with the seat, and foot pedals. If this were a car the grip is on the wheel, the seat is the major constraint and normally in a race car there would be a harness. My point is the sensory experience of the bike and car user is very different, even though the physics is the same, depending on the constraint/restraint, or otherwise, of a user.
    Which brings me to my last point, efficiency and practicality of motion simulation, which is often dictated somewhat by the constraints of the rig design, which also needs to be taken into account. In other words how you go about creating cues to exploit the weaknesses of human processing and perception may differ depending on what rig design is being considered.
  9. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,763Coins
    DC motor, 6DOF
    “Or you could say, it captures the acceleration data only when it growing either in a positive or negative direction.”
    I am smelling that this could be an old @yobuddy quote from times when Simtools washout had a dark side. This pumping effect was than corrected so we could interface 6-dof plugins.
    If this was an error in math or a specific washout approach from non-kinematic era, he is the one who can provide a response.
  10. hexpod
    berlin
    7,763Coins
    DC motor, 6DOF
    This is all wrong as you can see in the explanation above. Nevertheless I am open to search for alternatives.
  11. hexpod
    berlin
    7,763Coins
    DC motor, 6DOF
    I think it has less to do with friction. Even in outer space where two blocks are colliding I would expect the accel to return to 0 just after impact.
  12. Sverenja
    Sverenja New Member
    Bavaria
    631Coins
    Yes, the accel. goes back to zero, but doesn't cross zero and go negative. The new speed after the acceleration doesn't change again until another collision or getting to close to a gravity well.
    In a simulator that would be the first kick. The stopping at the end of travel is already not realistic anymore, even less the going back to home position. A full cycle in the sim is not one acceleration event, but four:
    (Let's call the direction of the first acceleration event positive)
    • a1 (positive): First kick, platform accelerates away from position zero
    • a2 (negative): Platform slows down until stop at end of travel
    • a3 (negative): Platform accelerates back in direction of position zero
    • a4 (positive): Platform slows down to full stop at position zero
    The space rock would only experience a1 unless it was sitting in a strong gravity well and being pulled back immediately after the collision and collide there again with another object causing it to stop completely and not just oscillate around.
    Acceleration going back to zero is not a second force, just the removal of force. Change of speed would be an additional force.
    It's not about a2 - a4 existing, they're necessary in a sim, it's about making them as unnoticable as possible. The bigger a1 the bigger a2 - a4 have to be unless the simulator is really large.
    That's also the argument for G-Seats as force (simulated acceleration) removed is just that - no more force.
  13. hexpod
    berlin
    7,763Coins
    DC motor, 6DOF
    It the data coming from the game is accurate, the only reason the back kick crosses the 0 on the simulator graph, could be that it simply adds the presence of back accel. to the washout which is supposed to act beyond the threshold of perception.
    Like I see on the real car example, the back cue is for me a completely natural phenomenon and not a false cue.
  14. hexpod
    berlin
    7,763Coins
    DC motor, 6DOF
    a2 and a4 is the washout which acts beyond of threshold of perception. What’s wrong with it ?
  15. Sverenja
    Sverenja New Member
    Bavaria
    631Coins
    a2, a3 and a4 are the washout, yes. They were never the problem. The problem was that the game reporting the acceleration being back at zero amplified a3 and therefore a4 in an unwanted manner raising them beyond the threshold of perception. That's why it was proposed that tying the reported acceleration directly into an axis for translational motion might not be the answer, but to calculate it indirectly from change in velocity.
    That's why I had the idea to do it with the derivative of acceleration and use the sign as a way to ignore one way, which was way too complicated considering v is already known ...
  16. Dirty
    7,952Coins
    It is both :) ...kinda... :) Depending on how you want to perceive it. A gear shift itself does not generate an actual measureable backwards acceleration (ignoring aero drag for now). Only human perception interprets it as such.
    But you guys see the symmetry here? The sudden absence of acceleration in a car is intuitively interpreted as a "kick back", and the same "kick back" on the sim could intuitively be interpreted just as the sudden absence of acceleration :) And on an ideal sim (no vibration, no outside visual, no noise, huuuuge operating space,...) those would be indistinguishable.
    Here, it is only the fact that the occupant does have other references that keep him from interpreting it as plausible.
    I know that this is not directly a solution for @alex928gt. But the realisation that a good sim should try to make it as hard as possible for the occupant to make this distinction is (I believe) one of the core concepts in motion sim building.
    I think of it like,... playing a prank on my own brain! :grin
    Oh,... I'm soooo going to fool this stupid dude!
    I'm gonna leave him no f'!%&§ chance!
    I'm-a-gonna strap him to that machine and blindfold him like that chick in 50 Shades....
    ...show him moving pictures of being in the cockpit 'n stuff!
    ...gonna take away his hearing!
    Hell,.... I'm even gonna rub this rig in kerosene and serve him bad coffey at 03:00 a.m till he don't know who his mama is!!!
    :grin:grin:grin:grin:grin
  17. alex928gt
    alex928gt Member
    397Coins
    Could not agree more. In my case I have a G-seat and I therefore need to feel the first forward kick from the horizontal actuator when starting to accelerate, then the prolonged effect of acceleration from the back of the G-seat. And, when I release the throttle, no backward kick but instead just the release of G-seat pressure in the back due to the removal of force.
    Removal of force is not an additional force. Some other forces - braking, frictions... - can however jump in at this point in time and should be acknowledged but this would be reflected by acceleration figure going into negative territory, not just going back to 0.
  18. alex928gt
    alex928gt Member
    397Coins
    No. What you feel in this case is not a horizontal backward kick equivalent to the one you feel on acceleration. It is 1/ a pressure release from the back of the seat and 2/ a strong tilt forward due to spring decompression.
    Conversely if you actually brake you get an actual backward kick like the seat going back very strong and fast and you wanting to continue forward but being forced to follow the seat backward because of your harness.
    Try it in a car with a harness, if you brake you will feel the strong pressure from the harness on your shoulders whereas if you just disengage the clutch (i.e. stop the engine force without generating braking from engine braking) you won't feel this same pressure from the harness.
  19. hexpod
    berlin
    7,763Coins
    DC motor, 6DOF
    What seat man ?
    The accelerometer was firmly attached to the car dashboard.
    What spring ?
    Look at the gyro, I don’t see much pitch rotation. (Angular velocity).
  20. hexpod
    berlin
    7,763Coins
    DC motor, 6DOF
    Alex, if you have a chance to drive a race car, I recommend you do a phyphox experience with a smartphone attached under your seat. You analyze the data, Than you try to reproduce what you did in your simulator, and with another phyphox experience, this time under the seat of your simulator, you try to tune it as close to what you did in the reality.
    I think doing so, you will see exactly where are your false cues and how eventually get rid of them.
    Make it sense to you ? What do you think ?
