News WRC Telemetry Patch 1.1
Discussion in 'SimTools Plugins' started by Mu-KwangKim, Jan 22, 2021.
  1. Mu-KwangKim
    South, Korea
    - 689Coins
  2. value1
    15,076Coins
    Thank you for the hint! Very exciting!
  3. stashy
    stashy Member
    india
    - 238Coins
    2DOF, SCN6
    anyone got it working with simtools?
  4. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    Hi yes it works
  5. stashy
    stashy Member
    india
    - 238Coins
    2DOF, SCN6
    my platform raises but no movement.what am i doing wrong?
  6. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    Make a shortcut on your desktop of the dirtrally2.exe that come with the telemetry fix
    then right click >properties
    In the target box add this to the end DirtRally2.exe /port 4123 /protocol simtools
    Example
    My orginal target box "J:\WRC 9\DirtRally2.exe"
    New target box "J:\WRC 9\DirtRally2.exe" DirtRally2.exe /port 4123 /protocol simtools
    then click Apply
    Use shortcut and it should load with simtools port 4123 and then run game as normal
    Dont forget there needs to be a space between the " and Dirtrally2.exe as in the pic above.
  7. stashy
    stashy Member
    india
    - 238Coins
    2DOF, SCN6
    Thank you will try it
  8. stashy
    stashy Member
    india
    - 238Coins
    2DOF, SCN6
    ok now it moves but very light movements and in tuning center i cant be able to capture roll and pitch movements
  9. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    Yeah it seems at the moment that pitch and roll dont work only heave, sway, surge and extra1 (traction loss i guess) still more than we had before.
    yeah if you own Dirt Rally 2.0 and have a working profile then you need to change the settings to suit WRC 9 and then swap them back to use DR 2.0 again so pain in the butt hole, but as i said before still better than we had before.
    The guy that shared this fix has also shared the source code so you never know someone might take it up another level. (not me im Thick :grin)
  10. stashy
    stashy Member
    india
    - 238Coins
    2DOF, SCN6
    ok thank you so much for your time lets hope someone can fix it
  11. wp8051
    wp8051 Racing simulator player Gold Contributor
    China
    224Coins
    AC motor, Motion platform, 4DOF
    Thanks for the setup method provided by the guy upstairs.
    I have tried it and it works very well.
    Looking forward to future updates, it is really much better now than before.
  12. Bulletpup
    Bulletpup New Member Gold Contributor
    117Coins
    Thank you! I have been looking for a way to get this working! Cant wait to try when I get home!!
  13. wp8051
    China
    224Coins
    I saw 4 DOF data in the turning center, namely sway, surge, heave, and extra1.
    Since the motion simulator I use is 2DOF, I only set up sway and surge. They can work perfectly and the effect is really good.
    At the same time, I also found a phenomenon:
    If I turn on the UDP forwarding function in SIMHUB, and the port points to 4123, then I can see the data change with "roll" added in the turning center.
    But the roll data seems to have no effect, and I can't feel its changes in the game.
  14. Bulletpup
    117Coins
    Here's the tutorial I made.
  15. wp8051
    China
    224Coins
    This is the video I played.
  16. wp8051
    China
    224Coins
    And this:
  17. wp8051
    China
    224Coins
    The last one :
  18. Andreawrc83
    Andreawrc83 Andywrc Gold Contributor
    commerciante
    italia
    73Coins
    It's possible to go with flypt? I've problem with simtool, don't go and flypt go very well..
  19. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    I've not used flypt so I have no idea if it will work, but you could try using the port number that flypt uses instead see if that works.
  20. estanislaolopez
    estanislaolopez Member
    Argentina
    80Coins
    2DOF, DC motor, SimforceGT
    Hi friends! With WRC 9 I have light movements and No Roll, no Pitch. Can yours share me your profiles configuration? Thanks a lot!
