Compact Racing Sim - 6 DOF
Discussion in 'DIY Motion Simulator Projects' started by early_m, Aug 13, 2020.
Tags:
  1. early_m
    early_m Active Member
    Chelmsford
    832Coins
    OK great, thanks, good advise
  2. early_m
    Chelmsford
    832Coins
  3. early_m
    Chelmsford
    832Coins
    Some design changes during lockdown 3 incorporating an f1 style seat
  4. RacingMat
    21,066Coins
    great!
    don't forget the dead pedal to rest your left foot
  5. XaviAlonso
    XaviAlonso Member
    España
    103Coins
    Amaizing, but, you considerer when the sistem go forward and declined to front plus your weight dont fall ? I think plus inertia's the leverage are a little close to the limit.
  6. Will974
    Will974 Active Member
    Industrial Ingeenering Teacher
    Reunion Island
    953Coins
    Hi!!!
    Is there some news about your project ?
  7. early_m
    Chelmsford
    832Coins
    I'm currently sourcing parts and putting together a 2 DOF setup for testing purposes. I've been waiting a long time for the motors but they've finally arrived today. So hoping to have a functioning sim in the next few weeks which I'll post about in my other thread. Once I'm happy the parts are suitable I will continue with the 6 DOF design
  8. SimPotato
    SimPotato Member
    Designer
    Gardiner, NY USA
    479Coins
    Fkntastic Work.. 3dmax vray? Would you share the files? I'm not interested in copying your design (which is really cool) but getting the models of some objects that I consider really well done. (Motor- power supply, joints light settings)
  9. early_m
    Chelmsford
    832Coins
    Thanks very much. Modelled and constrained in Inventor and rendered in Max with Fstorm. If I get the time I will try to share some files, but most of it was found online (try grabcad)
  10. SeatTime
    Nice render :thumbs will likely require outriggers for stability, or just fix it in some manner to the floor.
  11. early_m
    Chelmsford
    832Coins
    Yes there's only so much a 3D model and calculations can tell you. Will build it and combat any balancing / stability issues by incorporating a solution into the next revision
  12. R-power
    R-power New Member
    29Coins
    what a wonderful project !
    really congrats
    hope to see it become reality
  13. Fraza44
    Fraza44 Member
    Pensacola, FL
    652Coins
    @early_m hey what happened to your project? Are you still working on perfecting it or did it get shelved? Give us all an update at least.
  14. early_m
    Chelmsford
    832Coins
    Currently on hold due to financial reasons. I built a 2 DOF to test hardware and learn the software side of things. It's fulfilling my needs at the moment. But the dream is to still create the 6 DOF at some point.
    Here's the 2 DOF and it's got its own thread if you're interested https://www.xsimulator.net/community/threads/f1-style-2-dof.16071/
  15. Volvox
    Volvox New Member
    Ukraine
    1Coins
    DC motor, Arduino, 4DOF
    What arduino firmware did you use to control the test 6dof?
  16. early_m
    Chelmsford
    832Coins
  17. Robdog
    Robdog Member
    Newcastle, Australia
    104Coins
    3DOF, JRK
    I recently scrapped my 6 DOF rig and went back to a G seat, currently adding heave and pitch to it with 2 additional motors. I found the G seat to offer far better immersion than 6 DOF and was far cheaper to build. I am glad I did the 6 DOF as I would always have wondered how good they were, but for racing games I am not going back.
  18. Volvox
    Volvox New Member
    Ukraine
    1Coins
    Can you send a photo of what your g setup looks like now?
