2 Dof motion seat project
Discussion in 'SimTools Plugins' started by ALXXX, Jan 29, 2021.
  1. ALXXX
    ALXXX 2Dof Motion in progress Gold Contributor
    Stuttgart
    7Coins
    Hello guys,
    I'm building a motion seat.
    Unfortunately, I really have problems controlling the motors.
    I use a 24V 30A power supply for 2 motors, an Arduino Uno R3 and a Sabertooth 2x32.
    I can't get the motors moving with a potentiometer.
    But when I play around with the Sabertooth jumper, the motors start and run continuously.
    There's something wrong with the Sabertooth jumpers.
    I've been reading the forum for days
    Unfortunately I still haven't made it.
    Maybe someone could help me.
    That would be great.
    thanks, people
    153,986Coins
    +11,162 / 57 / -2
    Are you using @BlazinH's modified SMC3 code for Sabertooth, or something else?
    If so have you followed the wiring diagram and set the dip switches properly:
  3. ALXXX
    Stuttgart
    7Coins
    Thanks for your reply ! I triedbto upload SPS tobthe Arduino but while checking the file there is a problem. Something seems to be not correct with the sketch.
    Then i tried SMC3 and the connection is working. I can see something while turning the potentiometer
    But the motors are silent.
    Excuse me for my english. I will try my best
  4. ALXXX
    Stuttgart
    7Coins
    My port for sabertooth is Com 5 connected to the Arduino like in the perscription
    Arduino is Com 6 connected via usb
  5. ALXXX
    Stuttgart
    7Coins
    Eine Hand using a kangaroo 2, domt know if it is necessary or practical
  6. BlazinH
    16,691Coins
    You shouldn't be setting jumpers until you know what you're doing. Make sure to read and understand the SPS tutorial and that the 2x32 is set to 115200 baud using DEscribe software. https://www.dimensionengineering.com/info/describe.
  7. ALXXX
    Stuttgart
    7Coins
    I read and understood the SPS tutorial and tried to follow it.
    The baud is correctly. On Arduinonand Sabertooth. Both are on 115200
    When i try to open the smc util 1.0 or 1.01 i cannot open it.
    When i use another smc3 file i can open smc v 1.0
  8. BlazinH
    16,691Coins
    SPS is mostly the same code as SMC3 but with drivers for Sabertooth controllers. However utilities and the Arduino must communicate at 500000 baud so if you have a jumper on pin 8 to gnd it can't connect. That option should only be used if you have communication issues between Simtools and the Arduino or clone.
  9. ALXXX
    Stuttgart
    7Coins
    SPS i can upload in Arduino. But after tjis i cannot open any smc.util.
    Take a look at the picture....
    What do you mean with pin 8 ? This i dont understand
  10. ALXXX
    Stuttgart
    7Coins
    it is a shame
  11. BlazinH
    16,691Coins
    I mean the only reason I know of at this point why it won't connect would be if arduino pin 8 to gnd option is used to change baud from 500000 to 115200.
  12. ALXXX
    Stuttgart
    7Coins
    The Arduino baud is 115200....only in the settings of simtools it is writtennthat you should use 500000. By the way with simtools i have no connection to SMC3.
    And the main problem was that the motors are like dead. Theres no Impuls. Nothing. In germany we say ' i am finished with my Latinum ' haha....it is frustrating. I think i am not so far away from moving motors. But wheres the mistake ?
  13. BlazinH
    16,691Coins
    When you power up or reset SPS sketch it will automatically set its baud to 500000 unless pin 8 is grounded first. Utilities can only use 500000 baud because it doesn't have a way for the user to change it.
  14. BlazinH
    16,691Coins
    You need to get connected to utilities before this matters.
  15. ALXXX
    Stuttgart
    7Coins
    Excuse me, i dont want that you think i am stupid, but what doni have to do then ?
  16. ALXXX
    Stuttgart
    7Coins
    I will upload the SPS sketch first now again. And then ? What do i have to change to open a motor connection controlled via the potentiometer in SMC3 ( with your sketch )
  17. ALXXX
    Stuttgart
    7Coins
    Thank you a lot
  18. ALXXX
    Stuttgart
    7Coins
    I uploaded SPS 8.2 with softstart successfully on Arduino
  19. ALXXX
    Stuttgart
    7Coins
    Still the problem.
    With utils v 1.01 also with von 1.00
    Shit
  20. ALXXX
    Stuttgart
    7Coins
    Now i dont want to go back to the older SMC sketch which you already saw.
    But this was working. But the motors didnt react
