Question IBT 2 motor controllers
Discussion in 'Motor actuators and drivers' started by Jason 1979, Jan 18, 2021.
  1. Jason 1979
    Jason 1979 New Member
    60Coins
    Hi everyone, new member here, congrats to everyone on all your builds and knowledge! I'm in the process of building a 2dof and have a question regarding the ibt2 controller.
    Does anyone know if 2x ibt2 controllers can be connected to 1 motor to increase the power ? I have read that It might be possible but I'm still not sure. If someone could chime in on this please would be much appreciated. Thanks
  2. Gadget999
    12,007Coins
    151,608Coins
    +11,043 / 56 / -2
    It is possible: https://www.xsimulator.net/communit...tor-driver-more-power.5482/page-7#post-125407
  4. Jason 1979
    60Coins
  5. Jason 1979
    60Coins
  6. Gadget999
    12,007Coins
    I use 3 of them on my 6dof sim
    They have been very reliable
  7. Jason 1979
    60Coins
    Hi @Gadget999 the 100a controller arrived today, am I correct that it would use mode 1 smc3 ? If so, could you give me a rough idea on how it would be wired ? Cheers
  8. Gadget999
    12,007Coins
    hi Jason - i wired it the same as the IBT-2 iirc
    how many DOF is your sim ?
  9. Jason 1979
    60Coins
    It's 2 dof, currently running smc3 with ibt2 Chinese controllers. Mode 2
  10. Gadget999
    12,007Coins
    iirc its 2 direction pins and a pwm pin for each channel
  11. Jason 1979
    60Coins
    Would that be A1 A2 and B1 B2 are like the pwm pins on the ibt 2 ?
  12. Gadget999
    12,007Coins
    No i think
    A1 cw digital
    A2 ccw digital
    A3 pwm signal
  13. Jason 1979
    60Coins
    Ok cheers il give it a try, seems a good solid board for the money, what's the worst that could happen
  14. Gadget999
    12,007Coins
    Its a great board, there is a lot of built in protection and it can switch 100A i think it can switch 200a for short periods of time also !
  15. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    did you wired it? i just order 100a board like you and i want it to 2dof, could you please send phot of wiring diagram like full wire connected from the board to arduino please?, thanks in advance
  16. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    and is the problem solved?
  17. iLLuac4
    iLLuac4 Active Member
    896Coins
    Can someone post a schematics for the connection in Fritzing?
    #absyfadhel1 Have you solved your problem with this PWM?
  18. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    i received it broken so i return it and until now i didnt get refund LOL, i ordered 2 ibt-2 from aliexpress becuase i have 2 x ibt-2 now as for one motor and work great so i need extra 2x ibt-2 for the other motor
  19. iLLuac4
    896Coins
    Hmm ok. So you do not have any motor shutdown because of ibt-2 shutting down anymore?
  20. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    yes i used 2x it-2 for one motor and there is no shutdown
