Showroom diego navel - Project Assistance
Discussion in 'DIY Motion Simulator Projects' started by diego navel, Jan 29, 2021.
  1. diego navel
    diego navel New Member
    88Coins
  2. diego navel
    88Coins
  3. diego navel
    88Coins
    I already managed to change my code to mode 2, but now smc3 won't let me put my engines "on" to follow the steps
  4. andres50
    andres50 simulador de vuelo (flight simulator 2020)
    mecanico
    pamplona
    - 254Coins
    Hello, I had the same problem and I only had to turn the potentiometers a little and in the smc3 as in the photo press motor 1,2 or 3
  5. diego navel
    88Coins
    [QUOTE = "andres50, post: 212729, member: 31143"] Hello, I had the same problem and I only had to turn the potentiometers a little and in the smc3 as in the photo press engine 1,2 or 3 [/ QUOTE]
    What potentiometer did you use? And how are the motors activated to run?
  6. diego navel
    88Coins
    What arduino file did you use friend?
  7. andres50
    mecanico
    pamplona
    - 254Coins
    DC 5V Hall Angle Sensor Non contact Industrial 0-360 Degree Rotation Angular displacement Sensor
    bought on aliexpress
  8. andres50
    mecanico
    pamplona
    - 254Coins
    a picture is better than a thousand words, where the arrow points.
  9. diego navel
    88Coins
    how do you connect smc3 with simtools?
  10. diego navel
    88Coins
    I already have my motors connected, when I connect them to smc3 they already rotate, but when doing the test in simtools they do not move, much less in the game, please help
    152,541Coins
    +11,085 / 56 / -2
    Best to follow the SMC3 instructions: https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    Setup for Simtools 2:
    Interface Type - Serial
    ComPort = the Arduino ComPort, you can find it in Windows Device Manager.
    BitsPerSec - 500000
    Data Bits - 8
    Parity - None
    Stop Bit -1
    Output Bit Range - 10
    Output Type - Binary
    Interface Output - [A<Axis1a>][B<Axis2a>][C<Axis3a>]
  12. diego navel
    88Coins
    Yes, I did it as you are, the instructions for SMC3 but when starting sim tools and using the manual test, the motors do not move or anything
  13. noorbeast
    152,541Coins
    +11,085 / 56 / -2
    Please post pictures of ALL of your settings in SMC3 and SimTools.
    Does SMC3 behave as expected, as that has to be fully sorted before configuring SimTools?
  14. Marcelo M
    Marcelo M New Member
    67Coins
    Hello Friend! Today that I saw your message ... Did you get anything?
  15. diego navel
    88Coins
    Hello, excuse me, in what position do we put the potentiometer when connecting it to the motor?
    we need the engine not to make a full turn and that is what our engine tries to do
  16. noorbeast
    152,541Coins
    +11,085 / 56 / -2
    The pot or Hall Sensor feedback should be centered when the motor levers are in their centered rest position.
    Mounting and connecting a pot depends if gearing is required or not, direct mounting with a flexible coupling is easiest, but some pots require gearing: https://www.xsimulator.net/community/faq/how-to-connect-protect-a-potentiometer.13/
    The control code, such as SMC3, should be tuned to set the range of lever movement and to cut power if that range is exceeded: https://www.xsimulator.net/communit...driver-and-windows-utilities.4957/#post-48121
  17. Marcelo M
    67Coins
    Hello! No problem! I did the positioning of the potentiometers by SMC3Utils first with the motors disconnected, then just put the motors in the desired position and connect them in the potentiometers, but being careful not to move them from the alignment obtained in the SMC3Utils. And ready, after reconnecting the motors, when starting they should be stopped in the correct position ...
