WIP - RacingMat's closed circuit Gseat
Discussion in 'DIY Motion Simulator Projects' started by RacingMat, Dec 16, 2019.
  1. T R Para
    T R Para i make stuff up
    Cincinnati, Oh
    2,446Coins
    AC motor, 6DOF
    @RacingMat
    Have you run across any Arduino sketches that can use the serial output of Game Engine and output a signal to drive a relay board which in turn switches my air air valves on and off??
    Thanks...
  2. BlazinH
    16,691Coins
    To be honest I'm skeptical about using this approach since air bags have a finite inflation size. I hope I'm proved incorrect though.
    How will this improve control exactly? You're monitoring the internal pot but it appears still using the servos built it electronics to move the motor.
  3. cgodwin
    cgodwin Active Member
    Engineer
    Eugene, Oregon
    2,478Coins
    I'm really interested to see how this works out and how effective the simulation feels. One of my concerns about my JoyRider type simulator is it is rather dangerous, so this would be a good solution if it works well.
  4. RacingMat
    21,082Coins
    have a look in the FAQ about GameDash
    https://www.xsimulator.net/community/faq/gamedash-settings-tips-and-tricks.21/category
    driving a relay is extra simple: you change 1 digital pin (here pin 10) from low to high
    you should open a dedicated thread to get more specific help :)
  5. RacingMat
    21,082Coins
    Yes, that's right. I count on the bucket seat suited to my body size. Normally I won't be too far away.
    It harder to setup a PID based on a guessed position.
    With a simple servo, there is no way to tell where it is actually.
    I keep the built in electronic to give orders to the servo (it's convenient) but I use the internal pot to know where it is, how close it's from limits...
  6. RacingMat
    21,082Coins
    I agree, this design is elegant in terms of concealment and security. No moving parts around the seat, no chain, no gears... :)
  7. Trigen
    Trigen Active Member
    2,891Coins
    This project looks like it's going to be quite epic in the end. I recently been exploring xxpelle's project and found (as you do mention) that while it works very well for small changes given that there is some pressure once you quickly change direction or there is a large shift in force the airflow becomes restricted on 5mm tubing so i will change mine to 10mm or even 20mm. This could be negated with a system (piston) that also pulls the air out but it would probably add a lot to the cost and complexity to have pistons instead of the clamps. My current workaround is to hot glue part of the bladders to the top and bottom of the clamps so they do have some push/pull but that does come at a cost for the range of the bladder. Im actually going to do a combination of flaps and bladders so i can get the best of both worlds.
  8. Trigen
    2,891Coins
    Btw, where did you find the larger 27x13 (or larger if you got) something bladders? I finally found some but they got cancelled due to shipping issues to Norway
  9. RacingMat
    21,082Coins
  10. RacingMat
    21,082Coins
    I installed 4 wedges under the seat cover (taped with double-face adhesive tape):
    2 on the external face of thighs
    2 against the flotting ribs (but not activated yet).
    I really like it! :) Will finalize the setup and shoot pictures and vid
    Sustained effects are superbly given back.
    I'd advice to use the largest wedges to increase the contact surface.
    At start, it just requires to manually pump up the system to come to contact (so it's easily adaptable for different drivers).
    ;) I'm thinking about using the pump of a sphygmomanometer + pressure sensor to automatize the initialization
    FYI, I've given up the PID with pressure sensor in the loop (too much delay).
  11. Gadget999
    12,168Coins
    I have been planning to do air bladders, inwill use gearmotors and a cam and the smc3 program.
    How do you configure simtools how many motors ? One for each airbag ?
    Is it possible to use one motor for 2 bags ie left turn right bag, right turn left bag etc
    153,986Coins
    +11,162 / 57 / -2
    SimTools can currently handle up to 12 axis, 6 in group a and 6 in group b.
    How you would configure SimTools depends on how you layout and control the bladders, taking into account which motor is driving which axis. So yes, if you wanted to you could use one motor for 2 bags ie left turn right bag, right turn left bag. But you have other layout possibilities as well.
  13. Gadget999
    12,168Coins
    Makes me wonder if i could use the motors already on my 6dof to compress the bags
    If i place them in the right location might be able to use the motion of the sim to do the work
  14. T R Para
    Cincinnati, Oh
    2,446Coins
    AC motor, 6DOF
    @Gadget999 I have been working on an airbag system for what seems like a long time...
    And I spent (wasted) way too much money on it...
    But that is the way you learn I guess.
    The one thing I am convinced of is the seat can make your project much easier..
    I picked up a Kirkey 16800 Seat and the matching cover.
    I love the seat / hate the price...
    I went with an air compressor and solenoid valves..
    Although the motion is not linear it does have lots of power and is fast.
    Properly adjusting the turn on points with my diy control circuit and Game engine produces a pretty good feel...
    153,986Coins
    +11,162 / 57 / -2
    You could make them parasitic, but then you can't really tune the G-Seat independent of the motion sim, which given they are different but complimentary motion systems is likely not the best approach.
  16. Gadget999
    12,168Coins
    has anyone considered using a pressure sensor for pid control - but measuring the pressure in the bag not on the surface ?
    I am thinking it could work pretty good - you could even use a potentiometer to adjust the pressure
  17. T R Para
    Cincinnati, Oh
    2,446Coins
    AC motor, 6DOF
    I purchased a 30psi sensor from Amazon but never used it.
    I never figured out how to use it in a circuit.
    I just bought pressure regulators that went up to 30 psi which is the limit of most of the Wedge Bags.
  18. Gadget999
    12,168Coins
    I am pretty sure you just replace the potentiometer with a pressure/map sensor - the pid loop will regulate now with pressure instead of distance
  19. RacingMat
    21,082Coins
  20. Gadget999
    12,168Coins
    Hi Matt
    did you scope the output of the sensor ?
    do you think the delay was in the pid loop ?
    could the sensor be fitted next to the compression bladder rather than inline in the pipework ?
    did the sensor you use have any damping - (some of them have internal restrictors to keep the output smooth)
