Assembly of actuator peacemakers build, mostly
Discussion in 'Motor actuators and drivers' started by eloverphx, Feb 11, 2021.
  1. eloverphx
    eloverphx Member
    Electrician
    Shakopee, Minnesota, USA
    297Coins
    2DOF, Joyrider
    I just wanted to start a thread with my experience building a @Peacemaker105 , @SilentChill, and @Cannibal Smurf combination actuator. I have used parts from all of their builds to make my actuators and also built a couple of parts on my own. I will update this as I continue to assemble the actuators into their final product. As of now I have 2 assembled, but I still need to decide on how I want to do the upper portion that mounts to the cockpit. Not sure if I’ll go with rose joints or stick with a universal joint type setup.
    So here we go, I'll be doing this little by little when I have time to edit it and add photos. Might be out of order at first.
    Here is the push tube assembly.
    You need the following items:
    1 25x600mm tube
    2 m4x12 screws
    6 m5 nuts
    6 m5x80 screws
    6 m5 nuts
    Install your 6 - m6 nuts into the nut keepers.
    I ordered the wrong size screws. Instead of 80mm I bought 70mm. So I had to sink my nuts deeper in to the plastic slider part. I drilled the holes and used the screws to pull the nuts down into the part prior to attaching the ball screw.
    Slide the push tube into the plastic part and make sure it is flush with the lip on the inside. Then drill with a 3.5mm drill bit and tap with a m4 tap. We will install these screws after we insert the ball screw.
    Ball Screw assembly.
    Items:
    1 -1610 640mm ball screw
    1 -6mm grease fitting
    1 -10mm outside retaining clip
    1 -plastic anti-slap the inside of my pipe part
    Insert grease fitting into large hole on the ball screw nut. I used a little Teflon tape on the threads. Probably not necessary but whatever.
    Next take the plastic anti-slap part and install it on the top of the ball screw and secure with the retaining clip.
    FK12 bearing bottom assembly.
    Items:
    1- FK12 bearing
    4- m4x30
    4- m4 locknuts
    4- m6 nuts
    Insert bearing into plastic part. Mine was a extremely tight fit and needed to use slip joint pliers to push it in to the hole.
    Next insert the 4 m6 nuts into the outer nut keepers.
    Finally secure the FK bearing in place with the screws and locknuts. This is a good time to make sure you small 8x600mm rods fit in the remaining holes. If not drill them out to allow for a nice fit.
    Stay tuned more to come.
    Here's a link to my files and files from @Peacemaker105 and some from @Cannibal Smurf and I think I also have a part or two from @SilentChill. Make sure you have parts in hand when you start printing out these to make sure they are going to fit properly. I started printing right away and found I needed to make a lot of adjustments.
    https://www.dropbox.com/sh/xnvwjp1n6r9diyk/AACi96PeEIEptcKyN4p6XTFYa?dl=0
  2. RacingMat
    21,081Coins
    your pictures are not showing up...
    you can edit your title via the menu at the top of the message Thread tools / Edit title
  3. eloverphx
    eloverphx Member
    Electrician
    297Coins
    2DOF, Joyrider
    Thanks for the help. Found the drop down box for the title. The photos I noticed weren’t working so I was searching around the forums to see what I was doing wrong. I saw a thread a long while ago about it. Anyways when I go to edit the link address in the message the photo link info is gone. So I can’t change or delete the broken image. Any tip on that?
    153,728Coins
    It is best to upload images directly, as external links are not necessarily reliable over time, see the FAQs here: https://www.xsimulator.net/community/faq/upload-pictures-or-files.81/
  5. RacingMat
    21,081Coins
    You managed to upload the pictures on the forum! excellent
  6. Bravo-Fox
    Bravo-Fox New Member
    Suspension Engineer
    Sioux Center, IA USA
    - 15Coins
    @eloverphx
    Thanks for going through the trouble of documenting your build! I'm very interested in trying a build similar to yours/peacemakers design. Do you have accessible models for the printed parts you used?
  7. eloverphx
    eloverphx Member
    Electrician
    297Coins
    2DOF, Joyrider
    I can see about putting them together and sharing them. Give me a couple days. Peacemaker has his files on his build post. Mine haven’t been fully tested yet since my build isn’t assembled yet. The files I have is a mix from peacemaker, cannibal smurf and myself so there maybe some editin that might have to be done along the way.
  8. eloverphx
    eloverphx Member
    Electrician
    297Coins
    2DOF, Joyrider
    Just posted a link to the parts in the first part of the post. Let me know if it works or not.. Sorry for the delay.
