f1 2020
Discussion in 'Other Racing Games' started by SEELGAIN, Feb 11, 2021.
  1. SEELGAIN
    SEELGAIN New Member Gold Contributor
    - 39Coins
    3DOF, Arduino
    Can someone help me about this game?
    - I have installed the plugin sucesfully
    - I have patched the game
    - I run the game in directx 11 mode
    - No movement on my hardware...
    Regards
    152,265Coins
    +11,066 / 56 / -2
    Can you please post pictures of ALL of settings.
  3. SEELGAIN
    - 39Coins
    3DOF, Arduino
    Thanks for your answer
      63.1 KB
      428
      114.4 KB
      437
      107.9 KB
      426
      63.2 KB
      417
      68.3 KB
      412
    152,265Coins
    +11,066 / 56 / -2
  5. SEELGAIN
    - 39Coins
    3DOF, Arduino
    Tunning center seetings
    For the moment it´s empty...ussually I run a game first time with movement to set values but in this case no movement...
    Why are you using filters if thus far you don't even have motion?
    It´s same configuration that I´m using with other games that are running well...assetto corsa, beamNG,...
    I am presuming Output Testing works as expected, but just want to confirm that is so.
    Yes, output testing works as expected and also other games as it´s already said before.
    Have you tried to temporarily tried disabling the firewall and antivirus, reinstalling the plugin, to see if either are interfering?
    I will try it
    Try setting English Local: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
    I will try it
    Thanks a lot for your support !!!
    152,265Coins
    +11,066 / 56 / -2
    Presuming you have game data you need to capture TC Min/Max values and tweak from there.
  7. ludo22420
    ludo22420 Member
    206Coins
    hello does this plugin work on ps4 thank you
  8. DTHCR
    DTHCR New Member
    Queensland, Australia
    343Coins
    @ludo22420 I think this plugin is for pc only.
    You could try this one. I have this working on xbox - manual start, plus a pic of in game telemetry settings.
    You might just need to readjust max/min
  9. ludo22420
    ludo22420 Member
    206Coins
    it doesn't work thanks anyway
  10. DTHCR
    DTHCR New Member
    343Coins
    It was worth a try. you could try the one from vthinsel, i know it says its F1 2017 but i believe when settings are in legacy mode it works.
    i retested my F1 2019 plugin for ps4 and it works on xbox and for game F1 2020 in legacy mode, the other modes dont work.
  11. ludo22420
    ludo22420 Member
    206Coins
    these ok my ip address did not match now my platform is moving but simdashboard is disrupted now
  12. auspauly
    auspauly New Member Gold Contributor
    - 369Coins
    2DOF, 3DOF, AC motor, 4DOF, 6DOF
    with running 2 programs from 1 udp output does not work im using ugt dash and it has port forward and telemetry change my settings are 2776 to simhub from game in 2020 format forward to 2778 in 2020 format to ugt and forward from ugt to 2777 in 2018 format this gets simhub wind vibration ugt dash and motion working
