How to know the torque of that motors?? PLEASE HELP
Discussion in 'Motor actuators and drivers' started by Manes, Feb 13, 2021.
  1. Manes
    Manes Member
    179Coins
    hi guys, I get that motros for a low price. Now i need to calculate the chasis. For that i need to nkow the torque and rpm of the motors. Withe this information, someone can helpr to me, please?? They have encoder also. Is a good option to build a 2 dof?
  2. Zed
    USA
    5,845Coins
    There’s practical ways like with weight and an output arm, but there’s probably more sophisticated ways that might or might not be easier. Some web searches would probably give you some thoughts.
    Or, sort which part numbers you have and check manufacturers literature to see if you can just look it up.
    https://www.rossi.com/sites/default/files/Catalog_AS_Edition_April_2008_USA_issue.pdf
    That’s the US catalog but might have your motors and gear heads in it. Your photos don’t show the motor data plate well enough to get the numbers off it, but you may have all you need to just look it up.
  3. RacingMat
    21,082Coins
    you need a balance weight and a lever attached to your motor shaft
    you'll let the motor arm stall against the balance and see what you got
    watch out the motor temperature as stalling is not healthy for it...
    or use a torquemeter :p
  4. Gadget999
    12,132Coins
    they look like 450 watts
    what is the ratio of the gearbox ?
  5. Manes
    Manes Member
    179Coins
    [QUOTE = "Gadget999, publicación: 213399, miembro: 20168"] parecen 450 vatios
    ¿Cuál es la relación de la caja de cambios? [/ QUOTE]
    I dont know. I am searching the information but its dificult. Too much posibilities in the Rossi motorreductori
  6. Manes
    Manes Member
    179Coins
  7. Gadget999
    12,132Coins
    count the number of turns of the motor to one turn of the gearbox
  8. Manes
    Manes Member
    179Coins
    [QUOTE = "Gadget999, publicación: 213409, miembro: 20168"] cuente el número de vueltas del motor a una vuelta de la caja de cambios [/ QUOTE]
    How can i do It? :D
  9. Manes
    Manes Member
    179Coins
    Finaly today I contact with the builder and the motor has nominal 62 Nm, 100 Nm Max.
    El motorremotorreductor works at 30 rpm. It is very very slowly??
    This week I am working out if my house and i dont have the pc to work with the sim calculator
    153,788Coins
    +11,150 / 57 / -2
    Depends a bit on the motor max RPMs, but even so a longer lever will increase the linear speed, at the cost of some torque, you can mess around with those parameters in SimCalc.
  11. Gadget999
    12,132Coins
    are they 24v ?
  12. Manes
    Manes Member
    179Coins
    [QUOTE = "Gadget999, publicación: 213496, miembro: 20168"] ¿son 24v? [/ CITA]
    Yes, 24 v
  13. Manes
    Manes Member
    179Coins
    [QUOTE = "noorbeast, publicación: 213492, miembro: 10786"] Depende un poco de las RPM máximas del motor, pero aun así una palanca más larga aumentará la velocidad lineal, a costa de un poco de torque, puede jugar con esos parámetros en SimCalc. [/ QUOTE]
    I cheked with a rpm counter and the motor has in the axis 30 rpm. This week I Will do the calculate with the sim calculator
  14. Gadget999
    12,132Coins
    do you already have them - if so just go with them and see how you get on
    on the back of the motor is it a brake or a speed sensor ?
  15. Manes
    Manes Member
    179Coins
    [QUOTE = "Gadget999, post: 213510, member: 20168"] ¿ya los tienes? Si es así, ve con ellos y mira cómo te va
    en la parte trasera del motor, ¿es un freno o un sensor de velocidad? [/ QUOTE]
    It is an encoder.
  16. Gadget999
    12,132Coins
    ok - you may be able to use the encoder to get accurate positioning
    how many pulses per revolution ?
  17. Manes
    Manes Member
    179Coins
    I dont know. I need check on datasheet. Maybe i can to connect to Arduino??
  18. Manes
    Manes Member
    179Coins
    What drivers can I use to move the motors? What options can I have?
    153,788Coins
    +11,150 / 57 / -2
  20. Manes
    Manes Member
    179Coins
    H guys, i am come back at home. start today with the Sim Calculator. Is a beat difficult to me for the language. I dont understand very good what want to say the text. i make the calculate of the ctc with the lever in 120 mm and 200 mm but i am not sure I do the rigths parameters. I know the torque of the motor is 62 Nm and 30 rpm, I have this results, Are the parameters ok??
