Conflict issues SFX150
Discussion in 'DIY Motion Simulator Projects' started by Geoff McIntyre, Feb 13, 2021.
  1. Geoff McIntyre
    Geoff McIntyre Member
    236Coins
    I have just installed my actuators on to my rig after a decent test.. Everything was going fine until my Fanatec CSW wheel started lagging.. controls freezing for a split second. Tried various ports on a pcie card/motherboard and front ports but have had no success.. If i stop Simtools and keep it connected and powered on, but not running. My wheel works fine but as soon as i activate motion again, my wheel freezes..
    Help its been a bit of a slog getting to this stage..
  2. Geoff McIntyre
    236Coins
    Would EMI cause this?
    151,991Coins
    +11,061 / 56 / -2
    That would be my first guess.
    The other could be USB bandwidth issues, as onboard usb ports share controllers.
  4. Geoff McIntyre
    236Coins
    I just find it strange that when everything is on and Simtools is not connected, everything is fine..
    151,991Coins
    +11,061 / 56 / -2
    Those are the circumstance I would expect potential EMI and USB issues would be least, it is in use and under load that those 2 potential issues would be most prominent.
  6. SeatTime
    Just leave Simtools running with your actuator AC power off, should help you isolate the issue as either USB or AC EMI.
  7. Geoff McIntyre
    236Coins
    Ok i seperated all the power and data cables, and it really helped. Steering seems to be good now but i tried using my Steam Index. As soon as the motors get power, it greys out and comes back when you power off the motors.. My next question is.. do i need the DB25s shielded too or just the power??
    151,991Coins
    +11,061 / 56 / -2
    It does sound like you have found your culprit and shielding is likely needed.
  9. Geoff McIntyre
    236Coins
    But should i get DB25 cables too or just the power??
    Thanks Noorbeast for the input!!!
    151,991Coins
    +11,061 / 56 / -2
    According to @Thanos the DB25 male-male straight Molded cables have proper shielding that is much needed to deal with any EMI noise from the servo drive. Is that what you are using, or some sort of custom cables? If the latter then you would need shielded cables
  11. Geoff McIntyre
    236Coins
    I am just using standard moulded one's.. brand new not modified in anyway
  12. Thanos
    Electronics Engineer
    2,854Coins
    For your index you need to get and use this ferrite on the hdmi cable...
    https://www.digikey.com/product-detail/en/fair-rite-products-corp/0431177081/1934-1176-ND/8594003
  13. Geoff McIntyre
    236Coins
    What is so special about that 1?? @Thanos Is it because its 375ohm??
    It would be easier to source it in the uk if i know..
    While you are here Thanos.. How do i use the colour display as a spike filter on my AASD15a??
    thanks
  14. Geoff McIntyre
    236Coins
    I got it from a UK based company.. Arrives tomorrow ao hopefully gets it working..
    Going to order shielded cables anyway...
    Can you point me in the right direction of how to update my AASD15a to the latest firmware so i can use the coloured display...
    thanks
  15. Thanos
    2,854Coins
    The RGB screen is present on AMC-AASD15A v1.4 boards, is that what you have?
    With firmware v2.11 fix5 you just need to set Dip switches #1 and #2 to ON position to enable the color changes on the RGB display.
    The latest firmware is located here:
    https://github.com/tronicgr/AMC-AASD15A-Firmware/tree/master/Latest_firmware
    Thanos
  16. Geoff McIntyre
    236Coins
    I have V2.0.. Thanks i'll give it a go and see if i can update it..
  17. Geoff McIntyre
    236Coins
    Ok so i got it updated to v2.11 fix5 and have set the colours and moved dip2 to on, but no colour change??
  18. Thanos
    2,854Coins
    Again, what is the PCB revision on your board? Does it rotate colors red blue green on power up?
  19. Geoff McIntyre
    236Coins
    No it doesnt.. its blue all the time.. how do i check the revision on the PCB?? I bought it from you about 8 months ago
  20. Thanos
    2,854Coins
    Maybe you have the v1.3 that came either with black background yellow characters LCD or Blue background and white characters...
    RGB screen was introduced recently on v1.4 boards with the RJ45 connector on the back...
    Take a photo of your board to see the markings on it.
