Richard burns rally /rbr hu
Discussion in 'Other Racing Games' started by Krzysztof Dej, Feb 2, 2021.
  1. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,110Coins
    Worth to try. Rbr have reshade graphic and new fmod sound. Creators make new high quality stages and all is easy to install. Try in Google rbr pro
    I personally can't wait to get done my Diy 2dof and try rbr on it
  2. Bulletpup
    Bulletpup New Member Gold Contributor
    117Coins
    It worked great for me up until recently...cant get it to make the platform move anymore...
    I hope something isnt broken with the code or something.
    Its awesome when it worked! Love RBR Pro, makes it easy to stay on top of updates!
  3. Krzysztof Dej
    Poland
    1,110Coins
    I don't know about it becouse I make my own 2dof for now. It's take a long time when I can play. Maybe try patch it or remove rbr update. I install pro for myself yesterday ( I play on clean rbr and install all by myself) and I saw there is possibily to remove update. Maybe try this and patch game by simtools again
  4. Bulletpup
    117Coins
    I will try that! Hope its just an update that broke the patch and not something else. If that doesnt work, I will try an all new install on everything...not too happy it might come to that but I want motion to work with rbr.
  5. Krzysztof Dej
    Poland
    1,110Coins
    What platform You have? Have u any widomeo from rbr?
  6. Bulletpup
    117Coins
    Ive never heard of widomeo.
    As for my setup im using 2 scn actuators. The prosimu t-1000 2m specifically.
  7. Krzysztof Dej
    Poland
    1,110Coins
    Sieeesh writing from work with my phone and some word was change. I've meen youtobe wideo :)
  8. fernur246
    fernur246 New Member
    16Coins
    3DOF, SimAxe
    Hello.. Any luck getting rbrpro to work with sim tools ?
  9. Krzysztof Dej
    Poland
    1,110Coins
    If there is a plugin for rbr. I think it will be work with pro also
  10. jonathan22
    jonathan22 New Member Gold Contributor
    - 56Coins
    I already got it to work for me. Inside the rbrpro directory, there is a game folder in which the base game is, if from there you open the executable .sse it loads all the rbrpro configuration and the movement works. I have a shortcut of this executable and I always launch from this
  11. Bulletpup
    117Coins
    This is how I ended up figuring out how to make it work too...I'm disappointed that I can't just push the normal launcher. Everything works, VR Motion all your settings you set up seperately in the RBR Pro launcher.
    In case you are looking for it it is in the "Game" subfolder after you right click the launcher folder and click open files. Then you basically launch the game by the sse version not the no_sse version.
    I contacted one of the support members through Facebook and said I shouldn't have to do that. I didn't used to have to do that. Not until one of their updates stop letting it work for me. It was literally one day it worked, the next, nothing. That workaround seems to be the only thing that works with simtools. I even messed around changing the port numbers in RBR pro and couldn't get anything to recognize.
    Anyway, we have a workaround but not I have another issue...I can't get my motion to feel like it used to with this game. No matter what surface I am on there is a constant "bounce" with the suspension. I am driving the Ford fiesta wrc plus 2019 car and it just bounces my motion rig in a continuous fashion the entire stage. When I turn on smoothing factors it causes too much delay and the effects are too muted and laggy to be useful. I have also tried the global smoothing for every setting and can't get rid of it. Also tried tuning through the tuning menu but if I give the tuning menu too high of values I lose all the excitement of going over rough surfaces.
    Anyone experiencing the same. It doesn't do this in wrc or dirt rally...
  12. Krzysztof Dej
    Poland
    1,110Coins
    My 1st ride and dream come true
  13. Krzysztof Dej
    Poland
    1,110Coins
    Hi I have 2dof recently and feel the same. On assetto or dr2 movement is much more consistent and in rbr have or surge is ok but sway and roll is so bumpy. Have u found solution? I use clean rbr not pro or hu?+
  14. Krzysztof Dej
    Poland
    1,110Coins
    Simhub configuration for shakeit rumble motors and basshaker
      120.7 KB
      783
      153.5 KB
      567
  15. soplilloracing
    soplilloracing New Member
    España
    85Coins
    Hello..
    where is the game folder richard burns configuration to change the udp?
    The same thing happens to me one day it stopped working and I'm going crazy
  16. Krzysztof Dej
    Poland
    1,110Coins
    If u have rbr pro I heard that pro is making config files default always when game starts so I recommended to install rbr without pro or rbr with Hungarian plugin. This file is called Richard burns rally. Ini in main game folder
  17. REFFET NICOLAS
    REFFET NICOLAS New Member
    france
    - 34Coins
    Hello, is someone find the solution to use ngp6 physics in rbrpro last version ?
  18. Krzysztof Dej
    Poland
    1,110Coins
    A far i know ngp 6 is instant physics on pro launcher. Some cars working on both physics 5 and 6. When u install them u choose witch one u want.
    PS. Better to install hungary launcher :)
  19. REFFET NICOLAS
    france
    - 34Coins
    Hello, I will try it...
    Do you find the way to patch the game and use simtool ? I don't have any movement with last version of rbrpro
  20. Krzysztof Dej
    Poland
    1,110Coins
    I don't use pro. Carlo is making money for free game and not his mods mostly. I far i know pro rewriting all config files when start game so it's may be problem. I recommended to install clean rbr and rbrcit program ( u can downloaded all cars, sounds, and ngp) no need to pay Carlo
