Question Steering wheel 1:1 connection to encoder or gear reduction?
Discussion in 'DIY peripherals' started by WatchDoge, Feb 20, 2021.
Tags:
  1. WatchDoge
    WatchDoge New Member
    158Coins
    What are the benefits of using a one-to-one (straight up connecting wheel shaft to encoder shaft)
    or using a belt driven reduction?
  2. Gadget999
    12,156Coins
    Are you using a direct drive motor ?
    There will be no backlash or slippage if you use the encoder direct
  3. WatchDoge
    158Coins
    What about the encoder resolution change with gearing. If I'm using 1000ppr encoder and using 1:4 gearing will it affect the encoder output.
  4. Gadget999
    12,156Coins
    I assume you are not using a direct drive motor
    My suggestion is to put the encoder on the wheel
    But you could out it on the motor, is the connection a belt or a gear ?
    If the connection is a belt you may get slip
