  1. Zed
    USA
    5,845Coins
    Art, any new status? Soldering those pins could easily make all the difference on the way a working system. Also, I replaced the previous .ino with a new one that uses a #define to set whatever wakeup speed you want on the fans. Any S, R, or L commands take over as soon as received but it lets you have a default wind if you want it without having to open a serial monitor.
  2. ART FLY
    ART FLY Gettin' High on DIY :) Gold Contributor
    Bavarian State Theater, Decoration Stock Manager
    BAVARiA
    421Coins
    Hi ZED & hell YEAH new status :)
    I have a lot to do in my job and with schooling my son a.t.m.
    I was to tired to do a lot in the evenings ... :confused:
    BUT: I soldered the pins right after your pre last comment. AND there it was ... fans in motion !!!
    Look at the funny artful bubbles I created on those pins - soldering something as close as these pins for the very first time (will say I suck at soldering :cool:)
    The wind is only tested in Assetto Corsa at the moment. I can say it works :cheers increasing and decreasing as it should with the kph driven by my car.
    I think it only works right when I delete the MATHs line completely as it would be at 1 .
    My PSU is for 400W max. and I run all my three 160W motors and the two fans with it. Every time it is challenged too much over its maximum it has a stopping hick-up. The MM gets that hick-up in power too and than it is running at the last speed as before that hick-up until I push the GERÄT's emergency power off button. Once I release the em.pow.button the wind blows with the right force again until ... :rolleyes:
    So no big problems to see at the moment because I think I have one PSU lying around for the fans :D
    hug:
    ... and I will try the new .ino file today.
    Yours ART FLY
  3. Zed
    USA
    5,845Coins
    Hey Art, so happy to hear you got it all going! All that other/new/replacement .ino does is default to zero speed on reset or power up. I did that so people had to consciously choose to have a wakeup speed for those with VR and plugins that may not support wind. There’s no other difference between the version you have and the new one. If you’re happy with the built-in idle speed on wakeup of the older version, you’re good to go!
    And it’s tough sometimes to include the important details not knowing others’ experience levels. When you work with this stuff a lot, you forget that others may not have a background where they understand all the stuff that gets rolled up in saying something like “pop the MM onto the Arduino”. If everyone included all the detail, unfortunately it would blow things up the other way and take forever to post “simple” concepts. It’s a real problem with so many having such different backgrounds. We can use a shorthand of sorts to describe things where we assume, sometimes wrongly, that everyone understands what we mean.
    Photos, screen grabs, and questions/reports are really helpful, though, and I apologize I didn’t spot the lack of solder first view. I just saw the MM mounted on the Arduino in the thumbnail and it looked good from what I saw. It was only on looking closer after you were still having issues that I spotted the lack of solder. But that’s where detail on the part of those who might be missing that background gets important. It’s why I was asking for a breakdown and details of what things worked and what didn’t. That helps close the loop and both sides to understand where problems can be.
    But glad you got it going!
  4. ART FLY
    BAVARiA
    421Coins
    Don't blame yourself !!!
    Your help was awesome. I mean 'cause of you I came to understand by myself it had to be the soldering problem - without your great feedback and backup I would not have dared to go for it!
    @SilentChill s post on popping that one thing on the other ... I did not want to be reproachful - in NO way !!!
    I just wanted to give feedback to what a zero to hero guy like me would not ask and would not steel time from you if it would be added - okay?
    I am not a native English speaker. I am sorry it was misunderstood.
    :cheers Cheers from The Beautiful South - from BAVARiA,
    ART FLY
  5. Zed
    USA
    5,845Coins
    :cheers Cheers and the rig looks good!
  6. Alexander Monefeldt
    Alexander Monefeldt MPRSupercharger
    154Coins
    Greetings all,
    I have followed the instructions for the wind turbine simulation, but atm it doesn't seem to work.
    I am currently using and arduino UNO and Monster MOTO and have then same wiring done as in the thread.
    This is for Assetto Corsa Competizione, I have purchase the Pro license and downloaded/installed the plugin.
    The values are set up the same way that are at the start of the thread and still can't seem to power on the fans.
    I have the sim tools minimized and running and still don't know why it doesn't function. If someone can help me out, I truly appreciate it
  7. Zed
    USA
    5,845Coins
    153,697Coins
    If you are using cheap MM clones then please test them, as they are known to have significant quality control issues: https://www.xsimulator.net/community/faq/monster-moto-testing-before-use.158/
    It would also help if you post pictures of all of your settings.
  9. Alexander Monefeldt
    154Coins
    @Zed, I just tested it manually and it worked flawlessly, the problem that I still have is that I want to test it in a game and it doesn't seem to work. I am trying in Assetto Corsa Competizione by using Game Dash and I downloaded the plug-in.
  10. Zed
    USA
    5,845Coins
    @Alexander Monefeldt - if the wind system responds properly to manual commands, it sounds like it’s just Game Dash configuration. Posting screenshots and configuration might help diagnose but others are likely better to help now that hardware works. Cheers & good luck!
  11. Alexander Monefeldt
    154Coins
    This is my current setting in GameDash
  12. Zed
    USA
    5,845Coins
    Alexander, do you have any math in the command editor (the pencil) for Dash 1? There’s lots of examples in this thread of configuration in Game Dash. Since your system accepts manual commands, it sounds like you just need to sort configuration in Game Dash and SimTools.
  13. Caesardimxes
    Caesardimxes New Member
    13Coins
    3DOF, SCN5, SCN6, Motion platform, 4DOF
    If Avenga has removed his STL box designs cos he wants to make a million dollars from them, why are they still being referenced in the download sections?
    153,697Coins
    The FAQ page itself is just a gateway to all that member generated information and it continues to evolve, if there are mistakes, updates or corrections needed then please kindly notify where corrections need to be made.
  15. tomkil192
    tomkil192 Member
    Uk. London
    - 25Coins
    Hi guys,
    I need some help with the wind simulator setup for war thunder. Do i need some special parameters in the dash sim. Dash communicates and reads the values from the game.
    How to tel arduino to read TAS Km/h
    thanks
  16. tomkil192
    tomkil192 Member
    Uk. London
    - 25Coins
    I will download LFS and try from the basics but i will need help with warthunder
  17. tomkil192
    tomkil192 Member
    Uk. London
    - 25Coins
    so, it finaly works in LFS
    I had to reinstall sitools, game dash, plugins and it is alive but I cant get it working on Warthunder
    any ideas?
  18. tomkil192
    tomkil192 Member
    Uk. London
    - 25Coins
    It might help some people. It took me a while to find it.
    Moto monster test:
    • Check the video below:
    • Download Arduino code attached (moto monster test program.rar)
    • Connect your multimeter instead of motors (if you dont have spare motors)
    • use monitor function in arduino
    • Use + / - on your keyboard to increase or decrease voltage
    • Check the output both ways CW and CCW
    I hope this will help
    153,697Coins
    Unfortunately the War Thunder plugin page has states DashApp data: none
    So I expect @Ville Pesonen and/or @value1 would have to look at adding GameDash support.
  20. tomkil192
    tomkil192 Member
    Uk. London
    - 25Coins
    I will try to contact them
    thx
