Showroom A few years later, I'm finally ready to finish this 2DOF project!
Discussion in 'DIY Motion Simulator Projects' started by TL1000S, Feb 16, 2021.
  1. TL1000S
    TL1000S New Member
    China
    39Coins
    Safety first, install the four point safety belt and emergency switch before I dare to start the test.
    Finally began to test in the game, with the handle in the seat test a few laps LFS, feel good.
  2. TL1000S
    TL1000S New Member
    China
    39Coins
    At present, I feel that the setting is OK. Adjust it later.
    153,812Coins
    +11,150 / 57 / -2
  4. TL1000S
    TL1000S New Member
    China
    39Coins
    LFS has been running for more than 20 minutes, the temperature of MM is kept at 30 ℃, and the motor and power supply are cool.
      63.2 KB
      289
  5. TL1000S
    TL1000S New Member
    China
    39Coins
    153,812Coins
    +11,150 / 57 / -2
    That is likely because you need to first refine your motion profile, as suggested.
    Running such a low Intensity Level actually results in global smoothing, what you should do is dial each axis in individually first.
