NLR Motion Platform V3 w/Simtools?
Discussion in 'Commercial Simulators and Peripherie' started by Bulletpup, Feb 18, 2021.
  1. Bulletpup
    Bulletpup New Member Gold Contributor
    117Coins
    I have a friend that owns a Next Level Racing V3 platform and WRC 9.
    I newly discovered it was possible to use simtools for motion in WRC 9 with a bit of a workaround. Knowing this, I am wondering if there is a way to use Simtools software with the NLR V3 with some kind of redirect? I dont think there is official support but I feel it's possible given there are 2 motors driving the motion platform and I cant see those actuators being much different to drive than any others.
    Any thoughts/experience?
  2. KydDynoMyte
    KydDynoMyte Fool's Gold Contributor
    RTP, NC
    40Coins
    I haven't tried it yet, but I think the telemetry patch is just making the game work with the Dirt Rally 2.0 plugin. NLR software already supports Dirt Rally 2.0 I believe.
    153,722Coins
    It would likely be possible, but being a closed proprietary system Next Level Racing have indicated they are not willing to make it happen: https://www.xsimulator.net/community/threads/simtools-and-nlr-motion-platform-v3.10286/
    Nor do I suspect NLR's suggestion of using a hook pointer plugin to interface would be the best approach. Rather, it would be better to know what hardware is used and have a direct interface with it. In either case I am not aware of any NLR owner who has gone down either path yet.
  4. Bulletpup
    117Coins
    Lol, I think you got a bit mixed up. ;)
    Im talking about the WRC series not the Dirt series.
  5. KydDynoMyte
    RTP, NC
    40Coins
    I might very well have it mixed up. Wouldn't be the first time. But looking at the instructions of the telemetry patch for WRC it looks like it includes a DirtRally2.exe file you run to trick your motion software's Dirt Rally 2 plugin into thinking WRC is Dirt Rally 2. I have no idea how NLR software works but see it supports Dirt Rally 2 also. You might very well be able to trick NLR that WRC is Dirt Rally 2 in the same way.
  6. Bulletpup
    117Coins
    That's a good point. We need someone that knows about coding that also owns an NLR that could test that out...
    I dont think my buddy has any coding experience. But ya If we could use the same trick, it might just work.
  7. yobuddy
    51,523Coins
    Long ago, the first Next Level Racing platforms I saw for sale were from Alibaba, and they were sold as compatible with SimTools.
    So it is possible that a proper comport sniffer, to capture the sent data to the sim, would show us how to send data to these platforms.
  8. Bulletpup
    117Coins
    Thats great to know! Hope someone can bridge that gap in the future!
  9. Lukasz Gandecki
    Lukasz Gandecki New Member
    19Coins
    Motion platform
    It seems to me this might be easier than it seems.
    To give you an example - There is no GTA V in NLR tooling. Nonetheless when I used GTA V mod that adds Steering Wheel to it (Manual Transmission) it worked with NLR. That's because the mod "Exports UDP telemetry in DIRT 4 format". The only thing I had to do was to "activate" the dirt 4 profile in NLR. To tune it up I cloned it as a "GTA V - based on DIRT" and did tweaks there.
    In other words - the plugins do not seem to care what game you are actually playing (and if you are playing any). They just connect to a port that streams the data.
    And the piece that sends the data seems rather straightforward too ( I can't post links yet but a relevant file is on github at this path: E66666666/GTAVManualTransmission/tree/master/Gears/UDPTelemetry/UDPTelemetry.cpp - the
    E66666666 being the user and GTAVManualTransmission being the project name)
    If there was a way to export telemetry data from simtools in one of the known formats (Dirt, Project Cars 2, ACC, etc), it would all click together :)
    I'm a programmer and would consider doing some work in that direction if someone gave me some pointers.
    I'd also be willing to pay good amount of "real moneyz" for someone to get it done. (I imagine it would still be cheaper than me figuring it out from scratch taking my hourly rate into consideration).
    There is many more games available for simtools than it is for NLR so that would be a nice upgrade to a kit that I already paid a ton of money for.
    153,722Coins
    That sounds like controller based output, much like the SimTools generic joystick plugin, rather than genuine game telemetry based output.
    The SimTools telemetry API details is here: https://www.xsimulator.net/communit...lugin-for-simtools-2-0-api-documentation.131/
    But I doubt that will help.
  11. Lukasz Gandecki
    19Coins
    Motion platform
    Thanks for your answer.
    Do you mean the GTA V telemetry sounds like generic joystick output? That would be surprising since I feel when I bump into walls or other cars - for example (which joystick input wouldn't know about?)
    But, to be honest, that's besides the point - what I was trying to show is that NLR software can work with anything as long as it can connect to an UDP port that streams the telemetry data. I put NLR into "dirt 4 mode" and turn the "dirt 4 UDP telemetry" in GTA V mod and things start to work :)
  12. Bulletpup
    117Coins
    This is very cool! There is hope for NLR users.
    I guess NLR is the apple of the motion platforms...I guess that gives them more control of their eco-system but its a shame they dont have like an "advanced" mode for people that want to use the platform for a general motion device.
  13. lunaelise
    lunaelise New Member
    - 7Coins
    Hey, what is the work around? not sure where to start to get simtools working with my motion v3. thanks!
