Question GameVibe effects not showing up
Discussion in 'Official Companion Apps' started by Map63Vette, Mar 5, 2021.
  1. Map63Vette
    Map63Vette Active Member
    Mechanical Engineer
    Lawrence, KS
    709Coins
    I just recently upgraded my DIY license to a Pro one so I could run GameVibe with Assetto Corsa, but I have some questions regarding the setup. I was trying to set up all the effects before starting things, but when I select Assetto Corsa from the drop down menu at the top of the GameVibe window the effects list below it just says "GameVibe1", "GameVibe2", etc. It doesn't populate them with the effects that Assetto Corsa puts out. I have the same problem in the Tuning Center in that I don't know which effect is which for tuning them to set the highs and lows. Do I need to reinstall a plugin or something?
  2. Daguru
    Kitchen installer
    Wales uk
    460Coins
    Motion platform
    have you enabled vibe in game manager ?
      64.7 KB
      343
  3. Map63Vette
    Mechanical Engineer
    Lawrence, KS
    709Coins
    Yeah, I think I had to do that for the game list in GameVibe to even populate. Wondering if I need to reinstall a plugin or something.
  4. Daguru
    Kitchen installer
    Wales uk
    460Coins
    Motion platform
    Are you on track ?
  5. Map63Vette
    Mechanical Engineer
    Lawrence, KS
    709Coins
    Ah, that's interesting. The values only fill out when the game is active. They showed the correct names when the game launched, but weirdly they went back to "GameVibe1" and so on when I closed Assetto Corsa. Makes it a bit weird to try to get settings worked out before you play though.
  6. Daguru
    Kitchen installer
    Wales uk
    460Coins
    Motion platform
    I always set it up in game find it easier that way.
    Glad your sorted thou :thumbs
  7. Map63Vette
    Mechanical Engineer
    Lawrence, KS
    709Coins
    Well, it kind of works, but it's a bit of a hassle. If I have Content Manager open (my Assetto Corsa launcher), the names show up correctly, but when I'm trying to run tuning center the values zero out as soon as I close a race, which makes it tough to adjust them. Just seems like it doesn't work the same way that I thought I remembered the axis setup working for SimTools in general. I don't necessarily have extra screens to play with at my sim rig station, and all my stuff is VR so it's hard to play and look at a menu at the same time.
    Mostly just seems odd, that's all. It works fine, just fiddly to set up.
  8. Daguru
    Kitchen installer
    Wales uk
    460Coins
    Motion platform
    I see, I race in VR but still have my triples so simtools has got his own monitor :grin
  9. Map63Vette
    Mechanical Engineer
    Lawrence, KS
    709Coins
    Yeah, I tried to set the game up at my desk where I have doubles at least, but don't have my wheel and pedals, so a little more interesting. Did have a spare Xbox controller though, so could use that to get some info at least.
