2Dof +Traction loss - Its Finally Starting!
Discussion in 'DIY Motion Simulator Projects' started by Ian Pace, Feb 18, 2021.
  1. noorbeast
    152,553Coins
    +11,087 / 56 / -2
    I think your second option is a bit low for pitch torque and that the first is a better option and balance between pitch and roll torque:
  2. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    in the coming week i will re weigh all rig with peripherals and myself again to confirm the exact weight as i am sure it is less than the quoted 160kg, but i feel more comfortable overshooting as i dont know what i might add to the rig in the future.
    Im gonna go with the assumption that with the above values,. i should be good with approx 160kg.... at worst i will have to change the CTC i guess.
  3. Michael_miass
    Michael_miass West
    Russia, Miass
    725Coins
    Why do you have meanings with different signs? The rod and motor, judging by the photo, are on the same side
  4. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    Hi Michael,
    Yes i noticed that last night and in fact changed it. It gave me more degrees so i guess its a good thing as the torque figures remained the same :)
    Thanks for pointing it out!
  5. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    Traction loss structure in place :)
  6. czgui
    czgui Member
    - 110Coins
    Very good production, continue to work hard, do a good job of video sharing.
  7. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    Increased CTC from 30mm to 50mm, moved motors to still get a 90 degree angle, partially mounted traction loss motor.
    Structure is paractically complete from the metal work, i just need to relocate the gearbox plate as i got the Fanatec gearbox and its very high.
    I will soon start on the monitor stand and then sand and spray everything.
    Hopefully the above should be done by the end of month.... then its ready for wiring.
    The plan is that after i test everything and make sure everything works fine, i will close off the structure with some kind of lightweight panels, but still need to see what would be best to use.... IMG_1699.jpg IMG_1697.jpg
  8. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    MM cooling sorted.... just need to attach the heat sink.
    the fan is an 80mm 12v fan. Bit of an overkill :)
  9. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    Monitor stand ready - it’s a triple screen setup.... arms not mounted in that photo
    also staring with the first coat of primer on the stand.
  10. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    Monitor stand pained and complete :)
  11. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    Bench testing electronics and hopefully will get to install them over the weekend, once i spray the rig and take it upstairs.
  12. Stephen Robotham
    Stephen Robotham Active Member
    jamaica
    130Coins
    Looking good. Keep up the good work. It will be well worth it when completed.
  13. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    should have it partially running by the weekend!!! Honestly.... can’t wait! Feeling like a kid on Christmas Day haha
  14. Stephen Robotham
    jamaica
    130Coins
    Lol, I know the feeling. Once dialed in, it is truly an awesome experience. Consider adding some bass shakers once it's complete. I can't imagine my rig without those anymore, even more so than the motion at times, but together they truly make for an amazing experience.
  15. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    Yes already looking into them :) But to be honest i spent wayyyyy too much already as after i started building i decided to buy all the fanatec gear I needed (wanted) as before i just had a 920 :) so they will have to wait a bit.
  16. Stephen Robotham
    jamaica
    130Coins
    Understandable, but you wont regret it once you do. Welcome to the rabbit hole, there are many of us down here, lol.
  17. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    Today was a loooooonnnggg and productive day 8am-11:45pm! To say I’m knackered would be putting it lightly! But I am glad to say that it’s done and finally at home. Over the weekend I’ll put it back up together as I had to dismantle it to spray paint it and then start with the electronics.
  18. Stephen Robotham
    jamaica
    130Coins
    Nice job, you are 1 step ahead oh me. I still haven't pulled mine back down to paint it after 2 or 3 years. Good job.
  19. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    Didn’t want to try it before I paint. Cause I’m sure I wouldn’t have dismantled it again :)
  20. Stephen Robotham
    jamaica
    130Coins
    Good decision. thats exactly what happened to me. Set it up just to test and still hasnt been pulled back apart.
