SimTools v2 - Video Ride Creator v2.1
Create video ride films for the Video Ride Player
  1. yobuddy
    51,557Coins
    How did you get the error buddy?
    It started up just fine here?
    Chat soon,
  2. Sam Neall
    Sam Neall Member
    84Coins
    I am not sure. I launched it today for the fist time since I reinstalled it after I got a new computer in December. It worked fine then so I assume it is because of a windows update or something. I have tried uninstall/reinstalling the application and the same error showed up.
  3. yobuddy
    51,557Coins
    Antivirus maybe?
  4. Sam Neall
    Sam Neall Member
    84Coins
    I tried it with it off and the same thing happened.
  5. Sam Neall
    Sam Neall Member
    84Coins
    I also tried adding an exception in my antivirus. Any other ideas?
  6. yobuddy
    51,557Coins
    Sorry for late reply...
    Do you have another PC to test it on maybe?
    Could you show me a screen shot of the installation directory?
    (maybe antivirus quarantined something?)
    Chat soon,
  7. Sam Neall
    Sam Neall Member
    84Coins
    Here are the screenshots. I tried it on another computer and it works.
    C79815A2-4F64-4808-8BE5-4951898243A8.jpeg 46971FF8-7401-41A9-BA45-23FE775632F2.jpeg
  8. yobuddy
    51,557Coins
    Looks right to me!
    Maybe take a look at the quarantine section of your antivirus anyway, see if there are entries maybe.
    (What antivirus you using buddy?)
  9. Sam Neall
    Sam Neall Member
    84Coins
    I use windows defender. The last scan it ran didn’t find any threats so there is no quarantine that I can look at.
  10. yobuddy
    51,557Coins
    I bet if you install AVG Free or Avast Antivirus it will work again.
    Windows defender is not the best, and has been known to cause problems.
    Let me know how it goes,
  11. Sam Neall
    Sam Neall Member
    84Coins
    I tried both of those and the same error shows up.
  12. yobuddy
    51,557Coins
    Did you uninstall and reinstall SimTools once you switched antivirus's?
    (Maybe install it as admin?)
    I wish I could be more helpful, It's hard to diagnose what exactly is wrong when its an error a can't replicate.
    The error seems to be complaining about an unregistered dll.
    Since the 2 dll's used in this app are local and will always be found by the exe, it makes me think maybe a .net error?
    Maybe try the .net repair tool?
    https://www.microsoft.com/en-us/download/details.aspx?id=30135
    Anyway,
    Hope it helps.
  13. Sam Neall
    Sam Neall Member
    84Coins
    It's Ok. Thanks so much for doing what you can.
    There was a very recent update of .NET from windows. This could be causing the conflict. I tried the repair tool and the changes it made did not fix the issue.
    I did not uninstall and reinstall SimTools after the antivirus switch. Before I try that, how can I retain all of my settings? Also, I thought VRC was separate from SimTools considering it ran fine on another computer without SimTools installed. If you are talking about VRC, yes I tried reinstalling after using the antivirus and the result was the same. I also tried running the exe as admin.
  14. yobuddy
    51,557Coins
    Yes, that what I meant.
    If i think of something else i will be sure to jump in.
    Take care,
  15. giovannibellanca
    giovannibellanca New Member Gold Contributor
    Palermo - Italy
    355Coins
    2DOF, 3DOF, AC motor, Arduino, Motion platform
    Hi Yobuddy,
    in the meantime, congratulations on your work, truly excellent. I build motion simulators
    I followed all the instructions and built a camera and smartphone support to detect telemetry data (roll, pitch, heave, yaw, sway, surge) together with the video.
    But even if your software detects the data does it go off scale?
    The recovered data is m/s per time(s)
    What method do you recommend for recording telemetry?
    Thank's you.
  16. yobuddy
    51,557Coins
    @giovannibellanca,
    Thanks man!
    Awesome, I'd love to hear more about it!
    No because we can set a Max/Min in simtools to tune in the data no matter what scale or the unit is.
    You can also re-scale or smooth out the telemetry file directly with Video Ride Creator.
    Usually roll pitch and yaw is in degrees.
    And sway surge and heave is in g's
    (however, for a ride film, I would capture yaw in G's if its available.
    (Essentially 'traction loss' for a car video as an example)
    Take care buddy!
  17. giovannibellanca
    Palermo - Italy
    355Coins
    In the meantime, thanks for the quick reply and forgive my stupid English :)
    I translate with Google Translate. :)
    I'll try to send you a photo of the solution I found for the detection and I'll do some further tests with the telemetry, consider that the software all allow a detection of the axes with respect to the G-force.
    Too bad there is no precise guide of your software it would be really perfect.
    In addition, momentaneamte will adopt an alternative solution to show the video at 360 °.
    In this regard, I wanted to know:
    why have you not yet integrated the player with VLC that now supports 360 °?
  18. yobuddy
    51,557Coins
    It's on the list, its mainly just a time issue at the moment.
    Also last I checked the api for .net was still not out yet.
    Eventually I'd like to combine all of the video ride stuff into a single package, much like we are doing with simtools at the moment.
    Chat soon,
  19. giovannibellanca
    Palermo - Italy
    355Coins
    Hi friend, ok, I'll do some tests :)
    I look forward to developments on VLC I'm sure you will do a great job as you have done so far.
    I'll give you some shots of the cam for telemetry.
    We update. :)
  20. giovannibellanca
    Palermo - Italy
    355Coins
    Hi @yobuddy,
    excuse me just one more question maybe you can interpret something.
    Attached you will find two files the CFG with the telemetry data captured by the smartphone and the screenshot of the software after the import.
    Do you have any idea why this happens?
    It is definitely a scale and data problem but how can I solve it?
    Thanks again for your help.
