Question 6Dof Project with Odrive
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Acmed, Mar 22, 2021.
  1. Acmed
    Acmed New Member Gold Contributor
    70Coins
    Hello everybody,
    I would like to build a 6 Dof Simrig
    I already bought :
    3 Odrive 3.6 cards for 6 Actuators and my problem is really big because i don't have any knowledge concerning programming...
    So i started to follow the steps and i don't know how it works ...
    I succed to communicate the odrive card with the computer ok ...
    I followed your step by step video @SilentChill (thanks a lot) explaining how to program but at the step when you are on the odrivtool configurator i didn' found the "main.py" .
    I did a small rig test to know if it works but i don't know how to try it ...
    I wanted also how can you make the link between the simgame and the odrive card ?
    How can i be sure that this communication can work ?
    I also have the command table from @PeterW
    But i'm clearly lost ... i found an Odrivegui.exe
    But it doesn't work i don't know how to fix that problem also...
    I would be greatful if someone can take time with me to succed and resolve my problems ..
    1-connection to odrive ok but i don't know how to setup and config the odrive correctly.
    2-I have AMT 102V but doest i need end switches ?
    3- how to make the link between game engine and odrive card and all configurations .
    4-how to config an odrive on the easiest way ?
    5-I can give you my discord, can someone can take time to axplain me on live how to approch this config step by step ?
    I hope someone would like to help me , because im in a road-end.
  2. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,766Coins
    Hi @Acmed
    Wellcome at the Odrive community!
    There are some main steps that you have to follow to get the Odrive working for sim use:
    1. Read all Odrive building threads here in the forum...
    2. Install the firmware from @SilentChill (that is a custom made firmware from the great company insectatech)
    3. Install the matching my_config.json from silentchill
    4. Swap wire A and B on one side of your AMT102 encoder cable (if you have this encoder)
    5.Check the motor pole-pairs.
    5. Make a motor calibration sequence and save
    After restart, the motor should turn a little (making the index search) and stop in closed loop control (so you feel the resistance when turning the motor by hand).
    Ok... this are the first steps...
    Wickie
  3. Acmed
    70Coins
    Thanks a lot for your fast reply @PeterW
    I will try to find all the threads concerning odrive but in some points I'm lost ...
    Where can i find the @SilentChill files ?
    I'm really sorry because in my case programming isn't my best point ...
    I wanted to thank you guys because helped me with your threads and videos !
    And i started my project because you inspired me to build a rig !
    Have a great day !
  4. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,766Coins
    For the firmware and setup pls see this video from @SilentChill at Youtube
    Wickie
