6DoF SFX100+100 TL Surge Sway
Discussion in 'DIY Motion Simulator Projects' started by Historiker, Mar 1, 2021.
  1. luky_90
    luky_90 Member
    276Coins
    [QUOTE = "Historiker, post: 214859, member: 4542"] L'autista Thanos AMC è arrivato ieri! Ora devo trovare un po 'di tempo per configurarlo. Ho Surge, Sway e Yaw pronti per l'uso. [/ QUOTE]
    dove hai acquistato il controller thanos?
    Google Translate:
    where did you buy thanos controller?
  2. Historiker
    9,208Coins
    Hi Luky, please use google translate or other translation program to post in XSimulator.net. This time I will do it for you ;)
    I purchased it from his US website.
    https://www.thanos-motion.com/
  3. Historiker
    9,208Coins
    It is almost too pretty to cover up
  4. Historiker
    9,208Coins
  5. wannabeaflyer2
    london uk
    8,343Coins
    Hi @Historiker that must have been a mistake on my part , not sure when that was activated but definetly not intentional good buddy (it will be removed ) :)
  6. Historiker
    9,208Coins
    I was genuinely curious, lol. All good.
  7. Historiker
    9,208Coins
    Not pretty, but it works. .8mm nozzle rough draft quality. Definitely looks better out of the case :grin
  8. Thanos
    Electronics Engineer
    2,854Coins
    Maybe print on some carbon fiber vinyl...
  9. Historiker
    9,208Coins
    I saw that you mentioned the technique in your discord. I am ok with utility quality.
  10. Historiker
    9,208Coins
    I have not yet purchased extrusion but I really felt like printing something. They are printed for 100100 aluminum but will work with whatever size I choose. Leaning toward 100100 again.
    7 hours 18 minutes print time. .8mm nozzle rough draft quality.
  11. Historiker
    9,208Coins
    Messy preperation for motion. Wires wires wires. Still need to buy the parts for the sfx bits. But I do want to get the electric bits sorted for my surge, sway and yaw
  12. Thanos
    2,854Coins
    Get a server rack to hide them away!
  13. Historiker
    9,208Coins
  14. Thanos
    2,854Coins
    A beverage cart maybe? :grin
    • Funny Funny x 2
  15. Historiker
    9,208Coins
    Hmmm...beverage cart...need to add casters....
    :grin
    And serious cable management....
    Suggestion Thanos, put the control panel on top....
  16. Historiker
    9,208Coins
    My traction loss/yaw (ish), surge and sway motors are mounted and ready for use. Just need to decipher the AMC controller settings and I can fire those three up. Still need to order the materials for the four linear actuators, when my budget recovers.
  17. SeatTime
    Nice work:thumbs, but would recommend that you support the screw with a linear rail (maybe you are already planning to do this?), as they are not design to take lateral forces by themselves. Over time they will bend/distort causing all sorts of issues.
  18. Historiker
    9,208Coins
    @SeatTime good point, thanks for the comment. I had not thought about adding rails. The TL screw is a monster 1"x1/4", I used it because it was collecting dust in the shop. The other two are ultra cheap ebay items. Easily replaced if I have to. I am curious how well they will hold up in the current configuration but I had not really thought about the rapid direction changes and the mass involved.
  19. Historiker
    9,208Coins
    I did finally get FlyPTMover set up and working with surge, sway and traction loss. They work GREAT! Firing six .50s from the nose of an F86 Sabre really gives you a kick forward, the traction loss is even better than standard yaw for feeling the plane kick around in a rudder turn, and sway just rocks you back and forth with the turbulence....Wow freaking Wow!.
    Later this weekend I will set up iRacing and give it a spin(pun intended)
  20. Historiker
    9,208Coins
    Ordered 100x100 aluminum profile today (guess I should change the name of the thread again).
    A lucky find on craigslist means that I can CNC my parts rather than print them 1.25" (32mm) HDPE sheets will do very well indeed.
