Showroom SFX-100 Project with AliExpress Profiles (WIP)
Discussion in 'DIY Motion Simulator Projects' started by Groquest, Mar 24, 2021.
  1. Groquest
    Groquest New Member
    South Korea
    1,308Coins
    4DOF
    Hi, I'm building an SFX-100 project + aluminum sim rig with aluminum profiles from AliExpress.
    Here's my rig (without the motion simulator bit).
    3D printed components and profiles
    More components from AliExpress
    The cutting of the profiles are of sub-par quality. I'm worried if it will cause mechanical issues later. I do not recommend buying from AliExpress. But they are really cheap. It only cost me $100 for the profiles and 32 slot nuts including shipping fee.
    I bought them as a last resort because Kinetik did not ship my order for more than four months (I opened a dispute in PayPal and got my refund).
    Wired up and testing the motors.
    I used Wago connectors to daisy-chain the power cables.
    I went with the Thanos controller for my project.
    I will post more once I get the license for SimTools.
    153,986Coins
    +11,162 / 57 / -2
    DIY license eligibility works the other way around, one of the criteria is that the build thread show some effort in detailing the build and your thread should show the rig is completed ready for testing, as the point of the free license is to encourage, detail and showcase DIY rig building:
    To qualify for a free license:
    • You must be building a true DIY motion simulator. (Not built from a kit or purchased from a simulator seller, a model simulator does not qualify.)
    • Have a unique build thread or Showcase in DIY Simulator Projects. (The thread should show some effort, which means it should show progress to the rig testing phase.)
    • Have been a member of the community for at least 30 days.
  3. Thanos
    Electronics Engineer
    2,908Coins
    You can try the free FlyPT mover... (you can donate if you like it).
    And perhaps SRS later... ;)
  4. Groquest
    Groquest New Member
    South Korea
    1,308Coins
    4DOF
    Thank you, Thanos. I will give it a shot.
  5. Groquest
    Groquest New Member
    South Korea
    1,308Coins
    4DOF
    Someone messaged me about where to get the profiles:
    Here's the link:
    https://www.aliexpress.com/item/32796414687.html?spm=a2g0s.9042311.0.0.21bb4c4dvORuxu
    Place an order and send a message to the seller (do not proceed with the payment). They will ask you what exactly you need. Tell them what you need (cut to 250mm pieces and the slot nuts) and then they will quote you. In my case, $100 including shipping (slow shipping) and 32 slot nuts and M14 x 1.5 tapping all 32 holes. Bear in mind that I live in Korea, which is right next to China. Your shipping cost may be more expensive.
    If you want to go this route, you will need to purchase 32 M14 to M10 thread inserts which cost me about $30.
    Also you need 32 M10 bolts instead of M8 ones.
    Currently I am having a hard time inserting the threaded inserts because it is so tight. Not even my impact driver can do the job. So I'm using a long hex wrench to do it manually. I'm suspecting the tapping quality is not up to standard. So I recommend getting a M14 tap and do it yourself.
    Also this project requires a different set of stl files for the 3d printed parts as the shape of the profile is different from the one from Kinetik.
    You can get them here (it's in Korean, but you can see the file link in English):
    https://blog.naver.com/parkmini/222245894946
    Coin donations are very much welcomed. Thank you.
  6. Leihschirm46
    Leihschirm46 New Member
    IT
    Austria / Vienna
    71Coins
    3DOF, 4DOF
    very nice setup , you will have a lot of fun with sfx ,
  7. Groquest
    Groquest New Member
    South Korea
    1,308Coins
    4DOF
    Slider assembly. Make sure to not unscrew the bearing completely. Many sfx-100 tutorials mentioned this, and I had read them all, and I still made this mistake somehow. Took some good 10 minutes to shove the ejected ball bearing inside and put them all together again.
    Attaching slider assembly to the mount. It was a very tedious job screwing those four bolts into the mount.
    Watching Netflix while screwing these things helped.
    Inserting threaded inserts to the profiles. Took a lot of effort to drive those things inside. I used WD-40 in place of tapping oil. For some reason the M14 x 1.5 tap by the AliExpress seller was not quite compatible with my threaded inserts. So the threaded inserts kept getting out of alignment. I had to spend a lot of effort straightening the threaded inserts in the midst of screwing them in (by applying extra perpendicular force to the hex wrench while screwing).
    Rough edges and remnants of aluminum were filed away. I washed the profiles with water because there were aluminum dusts everywhere.
    I applied bearing grease on screw and Super Lube on the 3d printed sliders.
    I was very generous with the amount of grease. I hope they don't cause problems later.
    I went with 3d printed grease nipples to save money. All of them ended up snapping while inserting them to the ball screw. Do not even think of using them.
    Inserting the linear bearing. A lot of grease has been applied inside.
    The perfect fit of the slider makes it very satisfactory to put these things together.
    * Before this step, you need to put the T-slot nuts inside the profile. I realized this after the full assembly and had to come back to this step later.
    Finished building all four of the actuators. Phew!
    Fixed the motor drivers to the tray that came with server rack which will keep these things.
    All that's left is attaching the actuators to my rig! See you in the next post.
  8. Leihschirm46
    IT
    Austria / Vienna
    71Coins
    3DOF, 4DOF
    huiii, i wanna see the next progress :) and if your are done , the smile :)
  9. Groquest
    Groquest New Member
    South Korea
    1,308Coins
    4DOF
    Before attaching the actuators, I decided to give it a test run just to be safe.
    First, I had to cram the motor drivers and the Thanos controller in a server rack.
    It looks easy, but it isn't. It took me more than an hour to do this.
    Ready for testing.
    I used FlyPT mover program for testing.
    The actuators seemed to work just fine in Assetto Corsa. So I went ahead with attaching the actuators to my rig.
    Ready for test drive!
    Unfortunately, the motion was very jerky and unrealistic due to having zero knowledge about tuning the motion parameters (surge, sway, roll, etc.). I am nauseating right now after one lap of Nurburgring GP circuit.
    I could not find FlyPT Mover tuning tutorials so I guess I'll try it again with SimTools.
  10. Thanos
    2,908Coins
    Perhaps you want to try SRS... they have 30 days money back guarantee if you are not satisfied with it:
    http://simracingstudio.rurl.me/thanos
    https://www.simracingstudio.com/post/3-reasons-why-you-should-choose-sim-racing-studio
    Plus now it supports Space Monkey...
    https://www.simracingstudio.com/pos...car-4---5-star-wars-squadron-vtol-vr-www1-etc
    Quick start guide for AMC-AASD15A controller setup:
    https://bit.ly/3lX6ON5
    Tuning guide:
    https://www.simracingstudio.com/forum/motion-profiles/srs-2-0-motion-tuning-guide
  11. mprofitt
    mprofitt Member
    230Coins
    Did you use the same 3d printed actuator parts as on the SFX-100 website?
    I have the same issue with Kinetik and need to order aluminum elsewhere.
