FlyPT Mover 3.5.3
  1. Acebk
    Acebk New Member
    - 31Coins
    Have a 3 actuators SFX150 setup, 2 in front and 1 in the back. I’ve been trying to dial in my motion for racing. I want good movement but when I do that it gets jerky. When I add low pass filters to smooth it out then I feel like I loose a lot of detail and movement. Any suggestions on filter settings for pitch, roll and heave? Would adding spike filters help with the jerks?
  2. Trigen
    Trigen Active Member
    2,872Coins
    3.4.1 3.4.2 Maybe further back.
    Spike edynlp ldynlp does not work when used in pose filtering on 3dof with linear. Works as intended when used directly in pose.
    Rollover on roll in Pose:: From motion still dont work. Has not worked for 5+ versions. It will just go over to the other side. Pitch rollover works as intended.
  3. wannabeaflyer2
    london uk
    8,339Coins
    Hi Guys Quikie Question regarding Motor RPM simulation , im using mover for this but worried about the beating the actuators take before mover gets to Set Smoothing range , i have butt transducers and amplifier ( to be connected ) would it be better to use the New Mover transducer Module for this ooperation and spare the workload on the Actuator for other stuff .. the RPM Pose module is fairly easy to use But i could do with an little expalantion as to What some of the paramter relate to in lay mans terms as i hate chnaging stuff without at least knowing beforehand the impact , so example "Rotational vibration in degs " and " Transitional vibration in mm " What impact does No of cyclinders have on vibration feeling ? what doe Vibration % relate to ... ok hands up i make hard work of stuff but with your help i'll get there .. Cheers Guys
  4. Acmed
    Acmed New Member Gold Contributor
    70Coins
    Hello to everybody , i wanted to be greatful with @PeterW @SilentChill @Will974 my project about 6dof is rising up all your tutorials and advices were useful !
    So i succeed to launch the Odrivegui beta 3 and this is my settings :
    I hope im right , i followed the instructions from the tutorial of @SilentChill and i wanted to connect one engine to a game by flypt software (very usefull) and the website to connect and search game sources is very useful also ! so thank you very much !
    i don't know why i can't see the connection with the engine by the odrive ...
    I can see the two ports COM and i did all the settings but i don't see any connection between them .. so may i forgot something ... in the odrive gui config or in the flypt but something is missing ! lol
    Thank you again for your help !
  5. Avee
    Avee Virtual Pilot
    1,167Coins
    Thanks for your reply. I started working on a slightly different and even better solution. I will measure the pose of the rig with potentiometers (easy for a 2dof), and then feed the pose directly to OVRMC, for which I now have to write a plugin. My hardware for this is ready, still struggling with the plugin a bit. It will also lay the groundwork for any other method of arduino based pose measuring.
    Another question: With airplanes, on the ground, physics are different than in the air. Now specifically on the ground, I would like to "prime" sway and surge from joystick input (rudder and brakes), because the effects from the simulator lag too much. So my thinking was to already start a small effect from the joystick before the sway input from the sim takes over (high pass filter). However, in the air, I would rather want roll and pitch effects to be primed by the joystick.
    Would it be possible to add "air/ground" sources to the joystick input as well? It would take "air/ground mode" from any other active input.
  6. Avee
    Avee Virtual Pilot
    1,167Coins
    I think if you don't want to wear your actuators with all the vibration effects, you would not use the RPM pose. The effects are pretty much as they state. You can set a vibration that rotates or one that moves side to side (transitional). I guess the number of cylinders relates to the pattern of vibrations in relationship to the rpm. An 8 cylinder runs with less vibration than a 4 cylinder, a v6 feels different from a straight 6.
    If you want your transducers to handle all your vibration then you need to add transducers and you wouldn't use the pose from rpm. The transducers have presets for engine rumble. What I did was also add a rumble from engine torque, which makes the feeling stronger and rougher when the engine is working hard. Don't know if racing sims commonly report this metric though.
  7. Historiker
    9,208Coins
    I use bass shakers for RPM, etc. They work great, you can fine tune them to exactly what you want to feel and save your actuators for moving you around. I do this with my 6DoF (rotational).
  8. greatg67
    greatg67 Member Gold Contributor
    509Coins
    @Historiker can you share your setup? What receiver are you using to drive the transducers?
  9. Historiker
    9,208Coins
  10. wannabeaflyer2
    london uk
    8,339Coins
    Thank for the tips and info Guys, very much appreciated ..:)
  11. wannabeaflyer2
    london uk
    8,339Coins
    Hi Guys , well Transducers and Amp Fitted and running using Mover Transducer Module , Quick question , OK Up Front info im effectively Deaf without my Cochlear implant attached LOL so i very much rely on external feedback cues during my sim sessions ,
    Funny enough yesterday on one of therare occasion i have my hearing switched :)on im sure i could hear what sounded like speach through the transducers when i held them close to my Ear for test.. does this mean i have not set the Mover parameters correctly ( im using the RPM Preset) ...
    Excuse my ignorance but is this normal , i assumed Mover was using RPM data direct from the Sim ( FS2020) so did not think speach would be part of that frequency map ( i guess, i know speach frequency is hard to seperate so once again did i miss something )
    My Set up has the 300w mini amplifier being fed from onboard sound card via ( Green) 3.5mm stereo Jackplug to Amp via 2 RCA plugs ( left/Right Channels) and Powered by 12V 1amp PSU adapter ( only for initial testing ) driving 2 x 4Ohm bass shaketr units .. Cheers Guys ( be patient with me :) mechanics im fine anything else (whoosh over top of my head time )
  12. Historiker
    9,208Coins
    Just wanted to say thanks for the Thanos AMC output in 3.4.2, works like a charm. I only have surge, sway and traction loss set up so far, waiting on parts for the four SFX100 actuators but the three DoF that I do have working are excellent!
    hug:
  13. wingert
    wingert Active Member
    678Coins
    4DOF
    do you use Rfactor2 and get suspension values with the 3.x.x. from Sim ?
  14. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,763Coins
    DC motor, 6DOF
    Thanos string output is still wrong in 3.4.2 at least for 6dof
  15. Historiker
    9,208Coins
    I use 3DoF +TL+Surge+Sway. Seven motors overall. Seems to work very well so far.
  16. benmax
    1,552Coins
    Yes the right order axis is 3 4 5 6 1 2 . the problem is when you setup a rotating hexpod ths wrong string is always chosen ! I can't change the output string when selecting the rig into thanos output setup !
    I can change the output string but only with the rig selected ''none'' !
  17. wyh0607b
    wyh0607b New Member
    173Coins
    AC motor, 6DOF
    Hello, how are you? Have you managed to solved this problem?
  18. C1500
    C1500 Active Member
    1,119Coins
    AC motor, 6DOF
  19. Arlouze
    Arlouze New Member
    64Coins
    Joyrider, Motion platform, 6DOF
    Hello guys, I'm new here and tbh I'm kinda lost in Simtools and stuff.
    I just want to control a 6DOF platform with a joystick. I mean, no games or something, just control a 6DOF platform. Do you guys have any idea of how to do so please ?
    Thanks per advance for your help
  20. hooshang
    hooshang Active Member
    275Coins
    this:https://www.xsimulator.net/community/threads/joystick-plugin.6160/ may help:thumbs
