MY own 2 dof diy
Discussion in 'DIY Motion Simulator Projects' started by absyfadhel1, Apr 17, 2020.
  1. absyfadhel1
    absyfadhel1 Active Member
    bahrain
    556Coins
  2. absyfadhel1
    bahrain
    556Coins
  3. absyfadhel1
    bahrain
    556Coins
    153,824Coins
    +11,151 / 57 / -2
    I purchased the 60:1 gearbox separately from Motion Dynamics, after first trying the 25:1s, so not a cheap option: https://www.motiondynamics.com.au/worm-drive-gearbox-to-suit-industrial-motors.html
    Though Motion Dynmaics does have other 200W or 320w motors available with a variety of wormdrive ratios: https://www.motiondynamics.com.au/industrial/
    The 200w 25:1s will work on compact designs for moderate weight users, you do need to maximise the inherent design leverage, and they can be easily be back driven when unpowered plus do run warm under load.
  5. absyfadhel1
    bahrain
    556Coins
    what you think about this motor its will be good and take weight?
    https://www.alibaba.com/product-det...offerlist.normal_offer.d_title.123056ceCzdSED
    i think i will purchase this one https://www.alibaba.com/product-det...offerlist.normal_offer.d_title.123056ceCzdSED
    200w 200rpm 50:1
    you think its will be great?
  6. TheYellowBatman
    TheYellowBatman New Member Gold Contributor
    217Coins
    It took them a few weeks to get back to me. I ended up calling up before they got back to me as I couldn't wait. Their service is good and they sent the motor promptly.
    I see you are in Bahrain, is it possible for you to call them directly?
  7. absyfadhel1
    bahrain
    556Coins
  8. absyfadhel1
    bahrain
    556Coins
    i just receive alibaba motor {300w 12v 40n.m 50:1} ...but its can push me up , when its try to push the powersupply be so low , you think if i change it its will be good ? or the motor is bad?
    this is my simcalc
    153,824Coins
    +11,151 / 57 / -2
    What is the geometry of your rig and approximate mass fully loaded?
    The CTC should be OK for designs with plenty of inherent leverage, like shoulder and foot mounts, but is likely too large for a compact rig with high mass load.
    Our rigs do generate significant power spikes in fast reversals, hence personally I run one modified 600w server PSU per motor, though led PSUs are another cheap option.
  10. absyfadhel1
    bahrain
    556Coins
    my potentiometer green line in smc3 when i turn it left and right its go to last line down but when go up its just go to above middle? what's wrong?
    Note: i tried another potentiometer and reupload smc3.ino and try another vesrion of smc3 but nothing worked for me
    153,824Coins
    +11,151 / 57 / -2
    The green line should be centered at rest, it looks like your pot is out of alignment and needs to be loosened, rotated to center, then re-tighten.
  12. absyfadhel1
    bahrain
    556Coins
    its centered, i tried with new potentiometer and its same , i think its a problme with arduino code
  13. noorbeast
    153,824Coins
    +11,151 / 57 / -2
    You also have not set the Max and Clip values.
  14. absyfadhel1
    bahrain
    556Coins
    its not affected, all the problme my potentiometer not going all up but its go all down
    153,824Coins
    +11,151 / 57 / -2
    These are the basic steps for setting up SMC3:
    Initial Setup
    I strongly recommend you follow the steps below if this is the first time you are using SMC3 with your simulator to reduce the risk of damaging anything.
    8. Set Kp to about 400
    Max sets the range, clip the limit: https://www.xsimulator.net/communit...driver-and-windows-utilities.4957/#post-48121
  16. absyfadhel1
    bahrain
    556Coins
    i tried it, i have new issue the green line direct go down and not move ever , i get new pot and new arduino and it was the same problme i delete smc3 and reinstall it but nothing helped!
    153,824Coins
    +11,151 / 57 / -2
    A lot of members use SMC3, so the likelihood is you have a problem with your setup, hardware or both.
    But you will need to supply far more information for members to be able to make suggestions, including posting pictures of all current settings and I would suggest a video of the step by step configuration of SMC3.
  18. absyfadhel1
    bahrain
    556Coins
    Tomorrow i will post video for all with picture
    153,824Coins
    +11,151 / 57 / -2
    Much appreciate. Can you also please detail what hardware is being used and what related Mode, 1 or 2, you are using.
  20. absyfadhel1
    bahrain
    556Coins
    its mode2..arduino and IBT 2, and its both new and the pot also new i just upload the smc3 code and entered the smc3 utility and when i enter the green line goes and dont move again and moving pot not affected ,i changed wires and i tryied with diffrent pc but it was same problme
